Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-10-2009, 08:50 PM
Magritte is on a distinguished road
Red dot alignment
Does anyone know how the red dot alignment on the newer chinese machines work? Does it come attached to the laser tube or is it seperate? Could I possibly retro fit one to my existing machine?
The pain of having to set my machine up again after a blown tube 3 months into owning it is getting to me a bit.
Old 06-10-2009, 09:04 PM
zax15uk is on a distinguished road
You need to add a ZnSe beam combiner to the laser path.
The CO2 laser will pass thru but the red dot pointer which is placed at 90 degrees to the CO2 beam will be redirected along the same axis.
http://www.wavelength-tech.com/BeamCombiner.htm
http://www.sintecoptronics.com/BeamCombiner.htm
Zax.
Old 01-19-2011, 02:02 AM
GuiBerlin's Avatar
GuiBerlin is on a distinguished road
I bring back to life that old thread :-)
I want to add a red dot with my basic laser engraving machine too.
But won't that ZnSe beam combiner reduce the power of the main laser beam ?
Old 01-19-2011, 09:00 AM
It depends on the quality but most have very high transmission (>98%) for the CO2 wavelength (if they didn't it would heat up).
Most of the cheap systems don't even use a combiner, they just have the visible beam slightly offset. This works but at different heights you'll find some errors - but again, probably acceptable in most cases.
I've also seen a design where the visible beam diode was mounted on a solenoid shuttle that enters the beam path. You could switch between the visible and CO2 with a toggle switch. The CO2 was disabled when the shuttle was moved to the working position.
Zax.
Old 01-19-2011, 10:35 AM
GuiBerlin's Avatar
I'll go for the easy way then :-)
Old 01-21-2011, 03:27 PM
Dubliner is on a distinguished road
Zax, would you have any pictures of a combiner installed and would you just run the file or outline depending on your needs with the door open to disable the CO2, and thirdly, arethe visible & co2 transmissions on simultaneously or do you run it with on/off from your control board?
Old 01-21-2011, 04:32 PM
I would add a switch for the red dot on/off, but you can leave it on during cutting if desired - doesn't really matter.
Zax.
Old 01-21-2011, 05:40 PM
notexpert is on a distinguished road
Hi guys,
Here is one home made option for the red dot. Costs all together app. € 25,- ($ 33,-) including the laser module. The power source for the module is two AA-battery in serial (3V) with a switch. The beam from the module is reduced with a piece of PVC-bar ( with 1mm hole ).
Regards,
Hannu
ID:	124516   Click image for larger version
ID:	124517   Click image for larger version
Old 01-22-2011, 02:07 AM
GuiBerlin's Avatar
Great staff !
It is exactly that I am going to do ! Thanks for the pictures !!!
(have to figure how to cut the mount though...)
Originally Posted by notexpert View Post
Hi guys,
Regards,
Hannu
Old 01-23-2011, 12:28 PM
Litografa's Avatar
Litografa is on a distinguished road
Hannu, great idea! Of course there is one big problem - position of red dot laser and real laser are not fixed one against another but solution is good for chinese lasers.
  #11   Ban this user!
Old 01-25-2011, 05:33 AM
Litografa, you are right about the position - and it will only need a small hit on it to get out of align, so you have to check the position quite often. But it still work nicely showing the position on your work and you can also add another module on the holder for using it as "half autofocus tool"
  #12   Ban this user!
Old 01-25-2011, 12:14 PM
Blackjax is on a distinguished road
crosshair laser
Why not use a crosshair laser pointer
LB-15 Headstock alignment nlh Okuma 9 05-22-2009 08:34 AM
New DRO install Alignment Help. Cartierusm General Metal Working Machines 8 03-29-2009 06:27 PM
SL-3H Turrent Alignment TWyatt9 Mori lathes 2 03-17-2009 06:42 AM
Alignment Megaplow Syil Products 11 03-20-2008 12:58 PM
alignment problem, please help djh82uk General Metalwork Discussion 12 01-23-2008 03:54 PM
