| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hello once again i have got some (hopefully minor) problem with my laser engraver. it has been working perfectly but today refuses to preview or cut anything -instead error message is displayed on the machine " soft stop" and a series of beeps. jog, and laser pulse all work ok. any suggestions welcome! thanks KP |
| KP That's where you have stopped the x-y axis and tried to run a cut program that will run outside the machines parameters I'll asume your machine is 900x600. i.e if you set the x-y to say 400, 400 then download a mol to machine that has a size of 550x250 this will overlap the machine parameters by 50mm on each axis, the machine throws out a soft stop message hope this helps Rich |
| Rich, thanks thats exactly what the problem is ( thanks Frank also who has advised the reason behind the error ) - makes perfect sense now. So it appears that somehow i have inadvertently changed the machine to operate the cutting program relative to the head's current position. Rather than to absolute coordinates ( ie relative to 0,0 ) - as it was functioning previously. i assume this is a setting in Lasercut 5.1 software? - since i havent tampered with anything other than the jog distance on the machine control pad. any clues? Regards KP |
| I doubt whether you have altered any parameters. If you do a cut & position the laser head anywhere away from datum, once this cut is finished the machine assumes this is the datum point to start the next cut, if it's a larger cut from the previous cut it will throw out a soft stop error. Just try moving the laser head to allow sufficient x-y for new part & reload, should be ok from then. Alternatively datum the machine before each cut. i.e. push the datum button on the panel before you load a new cut file, the laser head will then move to where you have the laser start point in the software. Rich |
| Tags |
| laser mpc6515 jinan |
| "Runtime error 9 - subscript out of range" on Techno CNC interface | zhoudfoster | General CNC (Mill and Lathe) Control Software (NC) | 4 | 10-25-2009 10:57 PM |
| Continue subprogram after push "CYCLE-STOP" | dzga | Fanuc | 2 | 06-13-2008 05:18 AM |
| V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" | rfdoyle | Bridgeport and Hardinge Mills | 4 | 10-08-2007 03:35 PM |
| How do I stop receiving "News Letters" from the site? | CNCadmin | CNCzone.com FAQ | 0 | 03-03-2006 10:47 AM |
| Mach2 bombs when I hit the "stop" button | Stuff-Builder | Mach Software (ArtSoft software) | 4 | 09-28-2005 10:09 AM |
