Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-13-2008, 10:41 AM
nicolacycles is on a distinguished road
Questions about 4130 chromoly steel
I am thinking about purchasing a laser cutter to make some 3/16"-1/4" thick parts for bicycles from 4130 chromoly plate. I also make .049" thick stainless steel badges to be brazed onto the front of the bicycles.
I currently use a waterjet guy who is local to make these parts for me but due to the diameter of the waterjet stream it is difficult for me to design detailed artwork for head badges where there are tight inside corners. i find myself having to radius every inside corner to 20 or 25 thousanths so that the stream doesnt make a funky mark in the corner. This is unacceptible to me so I am looking at laser to answer my questions. I apoligize in advance for the amount of questions and yes I have searched around but find it very difficult to find the info I need.
Now for the questions:
How much should I be looking to spend on a machine that can cut 1/4" 4130 chromoly steel?
What minimum wattage laser should I be looking into?
If I get a more powerful laser will that mean I can cut faster therefore reducing HAZ?
What other features are important when considering a machine primarily to cut steel?
What are my software options?
and finally, if I just wanted to cut stainless .049 sheet what size/type of machine should i be looking for?
Old 12-15-2008, 09:27 AM
MacGyver's Avatar
MacGyver is on a distinguished road
If you're looking at CO2, you need something in the kW range... for YAG, you may get away with a couple hundred W for a decent cut speed.
Hi-TecDesigns.com -- Automotive Lighting Systems
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 01:40 PM
Need Help!- Milling 4130 Steel JWB_Machining General Metalwork Discussion 3 11-06-2008 12:04 PM
Turning 4130 steel? Pontiff51 General Material Machining Solutions 4 12-06-2007 11:20 PM
4130 Steel FAMOUSX1 General Material Machining Solutions 8 10-12-2006 12:16 PM
Turning questions - 304 Stainless & 4130/4140 Chromoly K-fab50s General Metalwork Discussion 13 10-24-2005 09:53 PM
