Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-13-2008, 04:48 AM
zaheer0047 is on a distinguished road
how to make a HX3040 to cut?
hi, i just bought a HX3040 from Rabbit.
i just installed it some minutes ago and run out some test for engraving, i can engrave but it melts the material as well and i was trying to cut out shapes with it but cant find a way to do that, can anyone help me out?
which software can i use also?
Old 12-13-2008, 07:50 AM
zax15uk is on a distinguished road
What is the material, and what do you have the power / speed set on?
I am no expert, only had my machine for a week but it sounds like you need to increase the speed and/or lower the power.
Old 12-13-2008, 08:27 AM
ooh ok so to cut i only need to slower it down and increase the speed? it goes same for if i wana cut through paper and stone?
Old 12-15-2008, 09:04 AM
You use power, speed, assist gas and focus to achieve the desired result.
Higher power and lower speeds will be more likely to cause burning/charring of the material, adding an assist gas (Nitrogen or CO2) will reduce it as will increasing the cutting speed or lowering the power. De-focusing also reduces the energy and can help with some materials but increases the kerf.
You will need higher power and slower speeds for engraving stone, probably 10W and 10cm/s would be a good start.
Old 01-12-2009, 08:56 AM
SkipW is on a distinguished road
Cutting: Increase power, lower the speed.
Engraving: Lower the power, increase the speed.
When cutting, try to only use enough power to cut your material. If your material will cut at 50% power, don't run it at 100% power, your tube will last longer. Paper should cut at very low power and fast speed. Stone... you can engrave it but you won't be able to cut it.
It is a trial and error process, most of us went through that also. When you find a setting that works on a certain material, write it down.
Hope that helps,
Skip
Old 01-12-2009, 09:04 AM
Originally Posted by Dongxulasers View Post
I am surprised why so many people want such kind of small machine to cut.
Me too !!!
Old 02-01-2009, 12:12 PM
simasur is on a distinguished road
Hi, I have a question. How I can adjust focus on my new HX3040? I donīt know how to do, to use with diferent width materials ( 2mm, 4mm, 7 mm,...)
Old 02-01-2009, 12:28 PM
I don't have the HX3040 but would imagine you adjust the table up/down manually. The distance from material to lens needs to be constant, probably ~2".
Old 02-11-2009, 05:33 AM
LaserNOT is on a distinguished road
Ok, now I am starting to play with "cutting" a little now. I have some 1/8" birch plywood and I did a trial cut. Had to use full power, cut speed default to 2, and I slowed it to 1 but didn't improve much and I had to make 4 passes for it to cut thru. Are the edges of wood supposed to be burned? Is that normal? It cut a fine line and the edges were pretty good, although burned to what I think is pretty ugly, painting will cure it easily but I have purchased some "shaped" wood animals that are lasercut and there is no sign of burning at all???? What am I missing? And I thought it took too many passes and the power indicator only showed 1/3 to 1/2 power used during the cut.
Old 02-11-2009, 05:37 AM
Oh yeah, when I said I am starting to play with cutting, perhaps I should have said, How do you get different "files" to cut in newly draw. I did cut out a star shape, but that was with the newly draw "octagon" option. Whenever I try to import a lineart "drawing" I want to cut out, all it gives me is the engrave option.? I know i'm missing a step or two here. Thanks
  #11   Ban this user!
Old 02-11-2009, 11:37 AM
Newlydraw works great with Corel, ArtCAM and TurboCAD. In fact any program I've tried.
You need to import a vector to cut, perhaps you are using raster images?
Export as DXF (I believe V12 worked best) and then import, select 'cut' from the drop down box (to the right of the X/Y location/sizes).
Zax.
  #12   Ban this user!
Old 02-11-2009, 11:54 AM
OK, so plywood isn't exactly the easiest. You may not be able to cut 1/8" with good results - and certainly not 'clean' like the ones you purchased. These were likely cut with several hundred watts at a much faster speed.
The epoxy needs higher power to cut, and that causes the wood to burn. Using a slower speed makes it worse, but is probably required with our limited power.
If you focus above the surface 1/16" the kerf will be slightly wider but you'll get less charring.
I often mask the surfaces with application tape (used for vinyl signs) and slightly wet it to protect the surface from smoke damage. It also helps reduce flare up which burns the sides - but some charring will happen. I added air assist to my machine, and have experimented with shop air, nitrogen and CO2. This helps reduce charring but doesn't eliminate it.
Try some 1/8" wood (not ply) and you should get much better results, I use less than 1/2 power and 2-passes to prevent scorching.
At full power the current reading is not at full travel, it peaks just over half way... sorry I can't remember the actual number.
Zax.
Rabbit HX3040 vs. WKlaser LG3040? CanAm Laser Engraving & Cutting Machines 11 02-01-2009 12:24 PM
Best Way To Make This? DroopyPawn General Metalwork Discussion 8 12-15-2007 11:34 PM
Anyone know how to make this? ImanCarrot General Metalwork Discussion 4 06-20-2007 10:37 AM
CNC able to make this? kentrob11 Hobby Discussion 92 03-09-2006 08:30 AM
How can I make cncman General Electronics Discussion 3 03-23-2004 01:49 PM
