| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| A Few Questions From a Laser Rookie I’m still in the design phase of building a laser machine. Decided to throw out a few questions here before I go down the wrong path. Here’s what I have: 50W Chinese CO2 Laser tube Power supply components consisting of a 45KV transformer with rectifiers – A 200K 100W oil filled Ballast resistor - .08uf smoothing capacitor with a 10M Ohm Bleeder resistor – Variac to control voltage to the tube 22-27KV ZnSe Mirrors and adjustable lens assembly Water pump and tubing 18 X !8 XY table operated by stepper motors and Gecko Drives. Digital Milliamp Meter for laser current path and Digital Temperature Meters to measure water temperature going in and out of the tube. Mach 3 machine control software. TurboCADCAM and Bobcad/Bobart software Questions: I’m considering a mirror-less design that mounts the tube vertically on a fixed gantry. The laser would point straight down onto the moving XY table. The laser output will be a few inches above the work. ….. Any problem with mounting the tube vertical? Will I need the focusing lens at this short distance? What is the best/recommended method to hold the glass tube securely to the support housing? Should I compensate for the amount of time it takes to turn the laser on and off? Is there a recommended maximum temperature for the cooling water reservoir? Will I need a fan to blow the smoke away? Where can I buy the honeycomb material that makes up a laser worktable? Is software available that will convert a picture file directly into motor movement and laser on/off commands? Will this laser cut through hardwood 3/16 thick? Thanks in advance |
Considering the amount of momentum you'll have to overcome for moving such a large table underneath the laser with any repeatable accuracy, laser turn-on time will be in the noise. Ignore it. No specific max temp for the water, but you'll want it as cool as possible without creating condensation in the tube. Blow the smoke away or foul your optics... your choice. Mike Null from St. Louis Laser has some nice cutting grids for a very reasonable price. http://www.stl-laser.com/ Software is available... Solustan is one, though it's not exactly inexpensive. Google is your friend here... 50W should cut through 3/16" without much of an issue, but you'll see quite a bit of charring. You may want to consider air-assist.
__________________ Hi-TecDesigns.com -- Automotive Lighting Systems |
| Be carefull cleaning any optics, there's a bit of a knack to it. Any scratches can cause localised heat build up which can fracture the optics. Oh and remember that Zinc Selenide is toxic in dust form. Oh and don't go near ZnSe with acids or alkalis, it gives off nasty gasses like Hydrogen Selenide or something (smells like garlic).
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| Chinese Laser Some Questions | graphpix | Laser Engraving & Cutting Machines | 6 | 10-29-2008 02:00 PM |
| Laser newbie questions | bgirit | Laser Engraving & Cutting Machines | 4 | 08-18-2007 12:18 AM |
| Some basic Laser Questions | Normsthename | Laser Engraving & Cutting Machines | 4 | 11-08-2006 11:19 PM |
| Laser PSU questions... | WilliamD | Laser Engraving & Cutting Machines | 9 | 10-17-2006 06:27 PM |
| Basic laser questions... | WilliamD | Laser Engraving & Cutting Machines | 2 | 08-24-2006 12:54 AM |
