Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-15-2008, 06:35 PM
dvdlock's Avatar
dvdlock is on a distinguished road
With cutting a shape from a bipmap image
Hi all,
I am using a Rabbit 4060 40W machine with LaserCut5.1.
I have had the machine a few months now and have focused mainly on engraving images.
I now want to cut some shapes from Acrylic. This hasn't been a problem using the various functions in LaserCut 5.1. However, I would like to us a scanned image for the shape.
I scanned a small image into my editing software (attached) tidied it up a bit and converted it to a bitmap as I would with an image for engraving.
With this file now open in Lasercut I can't seem to find a way to cut it out. I would appreciate if anyone could guide me through how to do this.
Many thanks
Dave.
Old 11-15-2008, 10:41 PM
SkipW is on a distinguished road
Dave,
Do you have a vector drawing program like CorelDraw? If so, you would import the bitmap into Corel and either manually draw a vector around the object, or use the trace function to create a vector.
Here's a zipped .ai file of that picture you posted. It's not perfect and I don't know if the size is correct, but after you import this into LaserCut, you should be able to adjust the size.
Actually now that I think about it, you can draw vectors with LaserCut also. Import your bitmap and use the LaserCut vector tools to make a vector around it, (I think... I don't have it right here in front of me.) then delete the bitmap.
Hope that helps,
Skip
File Type: zip Graphic2.zip‎ (1,021 Bytes, 49 views)
Old 11-16-2008, 06:20 AM
dvdlock's Avatar
Originally Posted by SkipW View Post
Dave,
Hope that helps,
Skip
Hi Skip,
Many thank for the response and the advice.
As it happens I do have Corel Draw. I have to go out right now but i'll give it a go later and let you know how I get on.
Thanks for the file, I'll try that first.
Regards
Dave.
Old 11-17-2008, 07:49 AM
dvdlock's Avatar
Dave,
Hope that helps,
Skip
Hi Skip,
Didn't get chance to try the cutting yesterday but I have just finished testing today.
It worked a treat, many thanks for your advice and the file you kindly did for me.
It turns out that part of my Corel Draw package was Corel Trace. So all I need now is a bit of practice with the software and I should be good to go.
Many thanks again
Dave.
Old 11-17-2008, 09:14 AM
Most welcome Dave. Glad that worked for you.
Corel trace is fairly good but you usually have to do a little tweaking with the results. Like tracing that ornament picture you posted, you would probably end up with an inner and outer line if you view the trace in simple wireframe view in Corel. If so, you would select all and ungroup the drawing and just delete the inner line, and use the Object Properties manager to make sure the line is set to Hairline for vector cutting. Then do a "Save As" and choose AI - Adobe Illustrator so you can import it into LaserCut.
I'm not sure about LaserCut 5.1 but with my LC 5.0 it likes me to save vectors as Adobe Illustrator version 7.
Happy cutting!
Skip
Old 11-19-2008, 06:33 PM
avetek is on a distinguished road
Interesting. I have to do similar conversions with some of my work and was put onto TraceArt as a raster/vector convertor - it is a very basic programme but achieves very good results - it appears easy to use and has a good tutorial package and is only about $80 US. You can download it and use it free and generate dxf files with their logo spread across it - the logos disappear when you pay for it - it is worth checking out for a play. My contact who is using it all the time tells me it takes a 1/4 of the time he would normally take to import and trace.
Old 11-19-2008, 11:31 PM
Thanks for the info, avetek.
How does that work with the demo program and the logo spread across a dxf? Is the logo a raster or vector? Why couldn't you import the dxf into Corel and remove the logo? Not that anyone would do that, it just seems like it would be easy to get around that.
Skip
Old 11-20-2008, 01:54 AM
The logo is a vector and can easily be deleted ,as you say, in Corel Draw or Autocad - given that it is only an $80 dollar programme it is no big deal. Pay the money and it goes away - Other than that the programme has full functionality - Download it and give it a go, I was quite impressed.
Ren Shape cadman General Material Machining Solutions 2 06-02-2009 07:18 AM
Need Help!- How can I use fonts in other shape? kamyabzahedi EdgeCam 1 02-06-2008 01:46 PM
How/what machine to shape a thin stainless plate to become a "half" egg shape ? Calico General Metalwork Discussion 5 03-24-2007 10:40 AM
RFQ – cnc-Shape cut out of ¼” MDF Board njtermite Employment Opportunity 6 11-28-2006 07:08 AM
G-code optimization and Cuttin order NeoMiller General CAM Discussion 3 12-10-2003 07:23 PM
