| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| laser power problem I am using laser pro spirit 18*24 inch bed Mostly I cut 18 * 24 sheets I have noticed that when I start cutting it cuts correctly when the mirror distance is ok. as the mirror distance increase suppose its cutting at 17 inch or at 24" the power its using to cut reduces it cuts fine from the starting as the distance increase power reduces does anyone know about it. |
| it is laser beam alignment Check laser beam alignment. Specially, in the far end X-axis |
| how to check alignment? |
Did you get a user's-manual with the laser? The alignment procedure should be in there. If not then you need to email the manufacturer for instructions. It is a fairly risky thing to do as you have to over-ride the safety interlocks and have your hands inside the case with a live beam. Getting burnt is a REAL possibility. The other thing you can check is to make sure the table is the same height from the lens at all places. Turn off the laser and unplug the power from the mains outlet. Gently try to move the lens carriage to the top left corner. If it does not move freely do not force it. If it does not move freely then you canNOT do the following you will break something. Measure from the table top to a point on the lens mount. Move the lens carriage to the bottom left and measure again. Do the same for the top right and bottom right corners of the table. If they are not all exactly the same then you need to adjust the table top with shims until they are all level. Dave |
| The best way is to get technical supports from your seller, in order to operate the machine with safety.
__________________ We are professional manufacturer of cnc router, cnc wood router, cnc stone router, laser engraving and cutting machine, inkjet printer, textile printer, eco solvent printer, large format printer, color banner printer, and so on. Sincerely welcome to be our distributor in your marketing. qingdao mingyang cnc equipment co.,ltd. Contact: Oliver Zhang Tel: +86-532-85985933 Fax: +86-532-85981144 Email: oliver@qdmingyang.com MSN: qdmysk@hotmail.com Http://www.qdmingyang.com |
| If you need user manual ,I can send to you! We produce laser engraving/cutting machines,you can visit our website and check our products! Alice sukelaser@yahoo.com www.sukelaser.com |
| CO2 laser power supply | KTP | Laser Engraving & Cutting Machines | 4 | 09-24-2009 04:53 AM |
| Need Help!- small laser power | bibi | Laser Engraving & Cutting Machines | 7 | 07-28-2008 08:48 AM |
| Co2 Laser power | oneeye | Laser Engraving & Cutting Machines | 3 | 07-24-2007 11:37 AM |
| Laser power output problem(unstable)!!! | khasabog | Laser Engraving & Cutting Machines | 12 | 12-01-2006 04:49 AM |
| What power laser to get? | SRT Mike | Laser Engraving & Cutting Machines | 15 | 09-23-2006 03:51 PM |
