04-01-2009, 06:28 AM
Originally Posted by Tom Winters OK OK OK
First off you are having a problem cutting paper:
Lower your power as low as your machine will go and still fire a beam. Second when you bring up your output commands (Layer, Test, Standalone if in CorelDraw or AutoCAD, or when using lasercut 5.0/ Right hand side of the screen when using LaserCut 5.1) select the colored layer that will be cutting, choose your apropiate speed, power, and overlap) then before confirming the command by selecting ok... you need to click on the button the is square and has dots in it (ex. [...]) This will bring up your advanced options. Lower your frequency from 20000 to about 500. This should help. If this does not make a difference, change your overlap. If you PM me I will give you my number and I'll help you out over the phone. |
I have tried to change frequency in Lasercut but it doesn't make any difference. I'm trying to cut EVA foam but I get really dark edges.
How is your Lasercut set? My settings in preferences for Motion card for laser control is "Analog settings", when I set to "PWM" I get clear edges, but I cannot control power for engraving, seems like it is always set to highest power.
Anybody any suggestions?
thanx in advance |
