Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-01-2008, 01:02 PM
Brian Queen is on a distinguished road
Setting origin on laser cutters
Is there an easy way to set the origin on a rabbit laser cutter? I want cut images on a piece of paper so registration is important. If I’ve moved the head for a new project and then want to return to an old project I would like the laser to start from exactly the same position as I’ve made a jig to hold the pieces of paper in an exact position. There must be a standard to way to deal with this issue.
I’ve played around a bit with the Datum but I guess I don’t understand it. It seems as though when I press the datum button it doesn’t always return to exactly the same position.
Brian
Old 11-06-2008, 02:43 AM
ArturoV is on a distinguished road
Me too
I was in the same boat as you till I gave up and do a practice run, then set my final piece. I believe the "Datum" bottom sends the laser head to the top right hand corner. Hopefully someone can add to this problem.
Need Help!- Inexpensive Laser Cutters/Engravers hubery Laser Engraving & Cutting Machines 2 07-14-2009 10:52 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 11:17 AM
about chinese laser cutters buddhafragt Laser Engraving & Cutting Machines 11 08-04-2008 06:00 AM
Fabric laser cutters mdiaconu Laser Engraving & Cutting Machines 0 12-18-2006 03:03 AM
Announcing a new UK supplier of Laser Engravers/Cutters Strelitzia Product Announcements & Manufacturer News 0 11-07-2006 02:25 PM
