Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-23-2008, 03:57 PM
slvr98svt is on a distinguished road
How thick of metal
Over the past year or so I have been in the market researching the best cnc plasma out there. However I am looking for better results for small hole finishes and what not. I am going to be cutting up to 1/4" maybe 3/8" steel sheet and am looking at cutting small 3/16" holes in them. Is it possible to purchase such a laser for a homemade type setup? I am looking at just using a cnc plasma table type setup only for a cnc laser. Like I said I am all new to the laser side of things and this could be one of the most outrageous questions asked, but I figure it was worth a shot. I have done no research as to how many watts it takes to cut this thickness nor do I know if you can purchase such laser except in an industrial made machine.
Thanks Alot,
Old 10-23-2008, 05:47 PM
MacGyver's Avatar
MacGyver is on a distinguished road
Several hundred Watts...
Hi-TecDesigns.com -- Automotive Lighting Systems
Old 10-27-2008, 07:58 PM
Derek Kern is on a distinguished road
Cutting Metal
You will need atleast a 400 watt laser to cut the 3/16" steel. I am guessing close to 1000 for 3/8". But I think you will find out that its going to be tough just to strap on a laser that big onto your homemade machine....You need a way tracking the metal and keep a consistent focus for the laser beam. Some call this a Height Follower. This is very crucial when cutting metal with smaller lasers like this.
You will need a oxygen assist as well. Also a way to modulate the laser to achieve no slag and optimal edge quality.
PM me for additional info.
How thick? lgalla Mechanical Calculations/Engineering Design 28 11-03-2007 01:23 AM
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 01:26 PM
Routing 1/32 thick sheet metal dbtoutfit DIY-CNC Router Table Machines 0 08-09-2007 03:10 AM
NEwbie Help, is this too thick for my TIG ? Calico Welding, Brazing, Soldering, Sealing 19 09-29-2005 07:16 PM
How thick is too thick? lookalion General Metal Working Machines 5 08-30-2004 03:08 AM
