| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi to all! I have chinese engraver with 80w tube, 1290 clone model and 6515 controller using Lasercut 5.1 software. I cannot figure out how to control PWM settings in software, no matter how do I change them I always get same results. Default value is 20000. I was trying values ranging from 1 to 50000 but no changes. Does anybody have any idea how to control this? My problem is when I cut some kind of foam (in my country we call it EVA foam) for making key-chain tags (sorry for my bad english) I get very charred and dirt edges. I know that when using Epilog or GCC laser you can change PPI values and hope that PWM setting have the same effect on chinese lasers. Thanks in advance Last edited by maxxex; 10-12-2008 at 05:29 AM. |
Yes, of course I'm changing settings and sending them to laser. At first I also thought that new parameters are not sent but then I changed speed and saw that everything is sent correct. |
| Hi maxxex I dont know if this will help you But i have a redsail m500 that uses the same software and power and speed can be reduces on the control panel on the machine My one has power and speed as a % on the contol panel and they reduce what the setting coming in at by that percentage ie.. 50w is the input from software and i have 60% set so i get only 30watts power thru the machine I dont know if u have the same control panel But i hope this helps Shadow |
| Chinese Welders | Degrom | Welding, Brazing, Soldering, Sealing | 31 | 06-20-2009 10:53 AM |
| About Chinese 100W Laser Engraver | graphpix | Laser Engraving & Cutting Machines | 4 | 09-02-2008 07:33 PM |
| Chinese tooling | zhagoox | General Metalwork Discussion | 1 | 06-21-2008 12:20 AM |
| chinese | wp2576 | OneCNC | 4 | 05-23-2005 03:17 PM |
| chinese motors | servo | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 12-30-2004 11:38 AM |
