Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-11-2008, 10:09 AM
oneeye's Avatar
oneeye is on a distinguished road
Paper cutting
Hi all, when I try to cut paper or cardboard they take fire, which could be wrong? focal? exaust system? i m using a desktop 40wco2 laser . thank you
Old 10-11-2008, 03:33 PM
SkipW is on a distinguished road
You need air assist. Do you have that?
Skip
Old 10-11-2008, 04:57 PM
oneeye's Avatar
Skip
yes, but must i use nitrogen? cause i try air and the paper fire with one laser shot
Old 10-11-2008, 09:10 PM
lamicron is on a distinguished road
Maybe you are out of focus???
Old 10-13-2008, 09:26 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
How much pressure are you using?
The hole in the end of the focus tube may be too big reducing the pressure. My setup has only about 10-15 psi bit it works good. Is your focal length more than 2" and if so it may be too far away for the air to blow out the flame.
You may need to extend the tube or increase the pressure.
If your desk top machine doesn't have an air assist I recommend you purchase a fairly good quality aquarium air pump (electromagnetic piston type) and strap the outlet tube close to where you cut.
Rich.
I am not completely useless.......I can always serve as a BAD example.
Old 10-13-2008, 09:28 AM
MonoNeuron's Avatar
Oh, I forgot. Are you cutting fast enough?
If your not then you may need to speed up the cutting as this also helps to reduce the flaming.
Old 10-13-2008, 01:45 PM
oneeye's Avatar
yes, i think the nozzle hole is too big, i ll try a reduction and test diference pressures.
ths for hints m8s
Old 10-15-2008, 08:52 AM
bisjoe is on a distinguished road
What settings are you using? With 40 watts you should be using a speed of 50% or more and less than 20% power.
paper shims 3axisrookie General Metalwork Discussion 9 08-25-2008 02:18 AM
Thermal Paper Smackre Printing, Scanners, Vinyl cutting and Plotters 4 02-16-2006 10:43 AM
Cutting Paper greybeard Laser Engraving & Cutting Machines 2 09-10-2005 03:29 AM
Model or paper space? CNCadmin Autodesk Software (Autocad, Inventor etc) 9 07-02-2003 09:26 AM
paper jig David454 General CAM Discussion 4 04-18-2003 03:59 PM
