| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I want upgrade my machine from 60W to 80W. My 60W laser tube was died(and spare one I bought with laser engraving machine- worked 5-10 hours) and now when I must bay new one I want bay 80W tube and power supply. Did I must do something special in software or just replace tube and power supply? Does mirrors and lens are same for 60W and 80W ? |
Hi BiBi, I just got a 80 watt laser machine and I think it would have been better to get the 60 watt for engraving. And the 80 watt is better for cutting. I will most likely get a 60 watt tube later and I am hoping that the power supply will not need to be changed? I plan on doing more engraving then cutting. Plus the fact that the 80 watt tube is longer so you may need to cut a hole in your cabinet to allow the tube to clear. Then you will need to fab a cover for the tube. If anyone knows if the power supply are the same please let us know. Chris |
| Hi Chris, I made order for tube and power supply two day ago. Now U said that 60W is better for engraving and 80w for cutting - can u explain that. Which problem I will have with 80W tube and engraving. I had problem with cutting plywood and when my 60Wtube died I decide to by stronger tube and manufacturer said to me that I must change power supply and I made order for both. He ask me for what I use laser(cutting or engraving) that give me correct tube. I said both and he said that will be choose tube for both ?! |
BiBi, The 60 watt tube will cut 10mm and a 80 watt tube will cut 20mm The 60 watt tube has a better pin point beam then the 80 watt so it will give better results. But I am just starting to learn about Laser machines. But I have read lots and have talked to suppliers about this topic. Chris |
| Hi Chris, I have never succeed cut more of 5mm plywood, normally I use 4mm plywood and many times I have problem with cutting 4mm and with other tube these few day before laser died have same result.I am changed lens and same result. |
| Laser Tube Help | FlyGuy007 | Laser Engraving & Cutting Machines | 14 | 09-06-2008 03:50 PM |
| What is best for scanning? Led or tube laser? | jaru-eri | Digitizing and Laser Digitizing | 0 | 06-08-2008 05:01 PM |
| Laser tube and lens | Mongkol | Laser Engraving & Cutting Machines | 3 | 09-14-2007 02:17 AM |
| Is my laser tube ok? | PaioX | Laser Engraving & Cutting Machines | 4 | 07-23-2007 04:34 AM |
| bad laser tube | CNCadmin | Laser Engraving & Cutting Machines | 40 | 07-03-2007 11:23 PM |
