| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi all, I'm looking for some help with my XZ-M-I rotary attachemnt settings. Fom what I understand I have to change the Y-axis Pulse Unit setting to work the attachemnt. Could anyone tell me how to calculate that setting based on diameter of the lasered item. I'm using Lasercut 5.1 on a 4060 SE 40W Many thanks Dave. |
| Many thanks for the reply. As soon as I saw your post I jumped up with excitement to go try it. Unfortunately, it didn't work for me. My test engraving is a circular graphic which is 40.5mm dia on to a 66mm dia glass. With the formula you suggested I get an oval about 21mm wide. I did some trials using smaller values untill I got it right but of coarse, it was only good with that particular dia. Thanks for trying. Dave. |
| Dave. |
| Could you tell me what the various diameters are that you use with this, and is it the XZ-M-I rotary attachemnt. Many thanks Dave |
I attach pictures of my rotary. I changed to allow recording cylinders with grip objects. If I have problems when the objects are not perfect or cylindrical shapes with irregular. Cylinders to be swiveled by the roller bearing the same gear ratio, so it is not necessary to make any change in the configuration of the shaft. Sorry but my english it´s bud Eduardo Montevideo - Uruguay Por si alguien habla en español MSN edecar@hotmail.com |
#10
| Thanks for the suggestion. Looks like I have to do just that. In the meantime I'm going to experiment to try to find the answer. Thanks again Dave Last edited by dvdlock; 09-30-2008 at 07:25 PM. |
#11
| That might give a better looking circle. Dave |
| Lasercut 5.0 and 5.1 | avetek | Laser Engraving & Cutting Machines | 23 | 10-18-2010 11:54 AM |
| Need LaserCut 5.0 | ArturoV | Laser Engraving & Cutting Machines | 6 | 12-19-2009 02:26 AM |
| Lasercut software | terry32506 | Engraving Machines | 3 | 07-28-2009 12:25 AM |
| Rabbit laser Resolution & lasercut 5.1 | dvdlock | Laser Engraving & Cutting Machines | 5 | 08-21-2008 09:07 PM |
| Rabbit Settings | ArturoV | Laser Engraving & Cutting Machines | 3 | 12-05-2007 07:41 PM |
