| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Hello, this should be a step by step procedure, you will need a suitable laser power meter for this start by locating syscfg.ini file and set (if not already) the following: LaserPowerTableNumber=20 LaserPowerTable_0=0 LaserPowerTable_5=5 LaserPowerTable_10=10 LaserPowerTable_15=15 LaserPowerTable_20=20 LaserPowerTable_25=25 LaserPowerTable_30=30 LaserPowerTable_35=35 LaserPowerTable_40=40 LaserPowerTable_45=45 LaserPowerTable_50=50 LaserPowerTable_55=55 LaserPowerTable_60=60 LaserPowerTable_65=65 LaserPowerTable_70=70 LaserPowerTable_75=75 LaserPowerTable_80=80 LaserPowerTable_85=85 LaserPowerTable_90=90 LaserPowerTable_95=95 LaserPowerTable_100=100 there will be many repetitions of this table make sure all are set the same, then we need to make a long square on our software and set it up to be cut at 100 percent power 1% speed, move the laser head to the center of the table and disconect the motors so that wen you send the square to cut the motors wont move but the laser WILL fire, remove the focusing lens setup the power meter and send the job, after reading the power you get stop the job and repeat using -5% power setting (100% - 5% = 95%), keep repeating the power measurments decreasing each time 5% untill you reach 0 post your results and i will get you the calibration chart to setup correctly your machine. thanks Eduardo |
That'll be a problem for lots of people! Those meters cost heaps.... ![]() Bob |
| They sure do cost heaps. what might happen if I were to mess with those numbers without actually measuring the power? What would want to change in order to get the laser to fire at lower power settings, which was my problem in the first place? Is that a bad idea? The rental option is not bad, and i may resort to that if i have to. thanks |
Well, it might depend on what country one is in - I haven't heard of any hire service In New Zealand (not looked very hard though! )Bob |
| What should you do after you measure ? Whichis the rule to set it |
| PWM calculation spreadsheet You use the attached spreadsheet to calculate the correct values to set in the INI file |
| Programming a MPC6515 controller | CARTOGATE | Redsail Laser | 9 | 01-30-2010 02:09 AM |
| Problem- Laser cutting machines | blue^ray | Laser Engraving & Cutting Machines | 17 | 03-14-2008 06:24 PM |
| Chineese Laser Machines and Tubes | Laser Doctor | Laser Engraving & Cutting Machines | 16 | 09-14-2007 04:11 PM |
| Engraving photographs with CO2 Chinese laser machines? | GDP | Laser Engraving & Cutting Machines | 7 | 08-19-2007 09:01 PM |
| CNC Laser machines | CNCadmin | Laser Engraving & Cutting Machines | 7 | 06-25-2007 12:49 PM |
