| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi, I built my first CNC machine about a month ago, pretty much the same as the one at http://www.buildyourcnc.com. I built it all from MDF because I can't afford the extruded aluminium that a lot of machines are made from. Trouble is, when Im cutting along some wood the router tends to twist to the left. This is because the cutter is rotating anti-clockwise and a force exists between the cutter and the wood, etc. My only solution at the moment is to cut extremely small depths, with many slow passes until finished. Not ideal. Im looking into using a laser on the gantry my router is currently attached to. Seen some 40W C02 laser tubes for about £150, which seems affordable. I guess you can work out the laser cut depth by dividing the drilling rate by the feed rate. Drill rate is calculated at: http://alumni.media.mit.edu/~yarin/laser/physics.html but quite a few thermodynamic properties to look up for your material. Boiling point or melting point of 3/4" pine anyone?!?!?!? I have 2 questions: 1. If the laser only cuts half the thicknes of my wood, could I just pass over it again to complete the full depth i require? 2.Could you use fibre optics rather than mirrors to direct laser energy from the source to the gantry? Thanks for any help offered. Regards Adam |
| You're not going to cut 3/4" of wood with 40W and have anything recognizable come out of it... it just isn't going to happen. You also won't be able to use fiber with the wavelengths of a CO2 laser... you need to go to YAG wavelengths for that.
__________________ Hi-TecDesigns.com -- Automotive Lighting Systems |
| I cut 1/8" wood all day long with my 30 watt machine, 40 won't cut much more than that though. Unless you have 100-150 watts you won't be able to cut anything thicker than 1/2" or so. You can take multiple passes to cut through something, you will need to refocus every 1/16" or so and the result will never be as good as if you had enough power to cut through it in one pass. My laser uses a printer driver to control the power and speed. I went through quite a bit of testing to determine the best speed/power settings for any given substrate. You won't find anything out there that will allow you to put in a substrate, laser power and speed and have it give you suggested settings, it just ain't out there... If it was, the person who created it would be very rich! That is the most difficult part of learning how to laser. Gary |
| This may fit in here, maybe not.... HEY ZAX! Ol buddy..... Big Spring again.... Been playing with a lot of wood and am liking it! Anyway, I build up a vector file from a bmp and it turns out swell, very detailed. I really love this ENGRAVED and probably even better RELIEF engraved, if that is the correct word. The box "around" the image is engraved away, leaving the image "raised". More correctly, at the same surface height as the rest except the 'relieved" area. Now, my question. So far, I have only been able to get the "rectangle" box shape. I don't know if it is possible, but can we change the "shape" of the "cutout box" ? (or the relieved area) to say an oval or something else? The rectangle will work, but you know, oval's would be swell. Doing some custom gun grip/stock work and a customer wants an elk sillouette with oval shaped background. I warned him that unless my PAL ZAX knows a way, and nobody knows it like you, then we will be stuck with the rectangle shape. Or maybe a workaround.... Thanks again. I see you are as always very busy helping everyone else around here. I wonder if you ever have time to do you own stuff....? Also, been having fair luck with the metal marking spray, although whenever I re-supply I will get the "paste" version. Just too much waste with the spray... Still works great though, I've done stainless, brass, aluminum and some kind of coated aluminum, can't say it was anodized because the laser wouldn't touch it. After I appied the spray, worked perfect. I was half expecting the anodize to "discolor" like all the little tag things do, but didn't even touch it at full heat. Anyway, thanks again, look forward to your message.... JT |
| Hey JT... Well sure you can have any shape you like, does not need to be oval or rectangular. When you create the .bmp image just fade out to either black or white (depending on your method, normal or reverse engraving). If you prefer to put a nice border on it you can do that too in any shape, just add it in your photo editor. I am traveling on business, in Taiwan for a couple of weeks right now after spending last week in Japan, so no time to 'do my own stuff' unfortunately. The business keeps running without me though, mainly CNC stuff and vinyl lettering but I am sure the laser isn't sitting idle either. The paste version is much more economical, and works great even diluted 2 or 3X the recommended amount. I also found it needs less power when thinned more, and the mark is still very clear. It seems to work best on stainless to me. Zax. |
You certainly don't have to use a vector, in fact if you want grey scale shading and pseudo variable depth the only method on your system is using a raster file but of course the setup may be more work. Regarding the Cermark. It depends on the quality of stainless, the better quality actually seems to take the process easier. I use between 6 and 9 turns, but my tube is losing power - on it's way out. I should have mentioned, I use the LMM6000 which is alcohol based (and typically mix it 1:6). I haven't had such good luck with the LMM14 product. I use a small airbrush setup and the water based product seemed to separate and clog the nozzle resulting in a non-uniform coating - which is essential for good results. The thinner coating seems to laser easier and produces the best results. Zax. (someone posted here a while ago the instructions to make your own, I never tried it but would be interested in the results) |
hi,if you want a laser cutting machine to cut wooden.I think our machine can suit for you. Becuase cutting wooden is difficult.you need use high power to cut.maybe should use 100w.now we have 100w can cut more than 10mm plywood. and i can give you very very good price. Detail information can contact me.dear. vivinar@live.cn www.vivinar.diytrade.com www.chineselaser.com.cn
__________________ We offer best quality and wonderful service. welcome to Zhiya. |
| Laser engraving wood | velocitygraphix | Laser Engraving & Cutting Machines | 0 | 03-14-2008 02:12 AM |
| Newbie Questions - Assembly Laser Cutting Machine | watxup | Laser Engraving & Cutting Machines | 2 | 11-01-2007 11:00 AM |
| Running Mach3 for laser cutting questions | CNCadmin | Mach Plasma / Laser | 9 | 09-14-2007 11:34 PM |
| which laser for wood cutting | colormecnc | Laser Engraving & Cutting Machines | 4 | 09-14-2007 02:05 PM |
| Wood questions from a metal cutting guy. | Stepper Monkey | WoodWorking | 5 | 03-16-2007 08:18 PM |
