Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-17-2008, 04:41 PM
spacer777 is on a distinguished road
co2 laser (LG900)
hi, i have purchased a 60w co2 laser from china, the problem i am having is the parimeter settings, the laser head crashes against sides, i have contact the company i purchased the machine from but they do not reply, it is a CO2 60W LASER, LG900, TABLE SIZE 600mm x 900mm, it wont enen engrave accuratly to measurements i imput, if anyone can help, please do it quickly.
thanks
Paul
Old 09-17-2008, 05:18 PM
grzegorz1965 is on a distinguished road
Define table size in LaserCut program,it must be equal to real sizes of worktable in laser device.If you turn the laser on ,first use datuming function.
This function let the machine know where the laser head actually is.
It can prevent crashing.If the parts for cutting are bigger to table size or they are out of area,program shows it, as an error but head does't move.
If the laser head crashes while datuming,it can be range switch problem.
Good luck.
Grzegorz
Old 09-18-2008, 07:48 AM
Good luck.
Grzegorz
thank you, i will try this, if it is a range switch problem, how can i deal with this,
thanks
paul
Old 09-18-2008, 05:24 PM
If everything with switches and table size is OK then you should check the "pulse unit" parameter.
Chapter6 User manual
If the datuming doesn'n work properly check parameter datum(Pdir/Ndir)
6.2 Worktable User Manual.
Have you noticed problem with one or both axis?
If you still have a problem,we will try to solve it ithe other way.
Grzegorz
Old 09-21-2008, 05:58 AM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
What happens when you 'reset' and the head moves to the home switches?
On my machine (also 900x600) and running lasercut 5.0, the table size looks like it's set in the options (CTRL+J) under Worktable where the X-axis range is set to 900.0 and Y-axis to 600.0
On both of those, the 'Pulse Unit' is normally set to 0.0056250000
Bob
Old 09-21-2008, 08:49 AM
parrameter settings
thank you all for your replies, the situation at present is when auto datumming the laser head seams to want to go further back than the set point, the laser head then mwill move round the table but stops about 150mm short on both axis, the settings in lasercut 5 are set at 900mmx600mm, i set the laser to cut a square of 60mmx60mm but actual size cut was 53mmx53mm
paul
Old 09-21-2008, 03:31 PM
Smile
After you turn the laser on,run the laser cut program.
Then you should pres "RESET" on control panel.
The laser head should go to the right "upper" corner and stop.
If the table size parameter is OK ,the head will no go out of table area.
Now the 'Pulse Unit' is very important parameter but not only.
The second parameter is industrialy set by dipswitch in step motor controler.
Try to read pulse unit and dipswitch setting if you can,and send in next message.(for both axis)
I think this is the main reason of your troubles.
You can send picture of switches ,it can be very usefull.
We try to solve the problem.You must start use your laser and earn the money at last.
regards
Grzegorz
Old 09-21-2008, 05:48 PM
SkipW is on a distinguished road
Spacer,
Did you first download the config file from Lasercut into your laser machines memory? Did you get a beep tone when it completed?
Skip
Old 09-22-2008, 07:10 AM
Yes.
The first question is ,what kind of controler you have in your laser.
Is it Control card in PC or Controler in laser conected USB cable?
How could I forget to ask you
Regards
Grzegorz
Old 09-22-2008, 03:01 PM
thank you everyone, my problems are over for now, my pulse settings were all wrong, and after resstting the measurement status, everything seems fine, thanks again, especially to bob (kewikiwi) who sent right settings
paul
  #11   Ban this user!
Old 10-04-2008, 09:38 AM
Sorojchi is on a distinguished road
I also have a problem with the LG900
I was working on the LG900 (pci, LaserCut v. 5.0)without any problem. I just engraved a logo and was working with the software with the machine on, drawing some shapes and adding a bitmap image when suddenly the software started calculating and behaving strange.
I thought it could be the softare, and I even completely formatted the hard drive of the pc, reinstalled windows xp, reinstalled the laser card drives, reinstalled LaserCut 5.0 and the dog. After reinstalling LaserCut, I did not change any parameter. This did not fix the problem.
What happens is this:
I start the laser, open Lasercut. Everything is OK so far.
I can move the laser head on x and y and z from the software, no problem.
If I hit datum on the pc, the laser head moves to 900,600 just fine, but then hundreds of windows pop up saying “data exceeds working table”. I have to close Lasercut. When I open laser cut again, the laser head starts moving diagonally to 0,0 and hits the table, trying to continue to move on that direction. The only way to stop is pushing the emergency button. The buttons at the control panel in the machine do not work either.
Other problem is that if I draw any shape, for example a rectangle, the machine starts to calculate immediately and the laser starts working without me pressing the “begin” button, and the laser does the same shape over and over again. The only way to stop the machine is through the emergency button because nothing else works.
Since I reinstalled the software even formatted the hard disk and reinstalled windows xp, it does not seem to be a software problem.
How can I correct this?
Of course this happened in the middle of a production
Thanks in advance for any input.
Sorojchi.
  #12   Ban this user!
Old 10-24-2009, 02:06 AM
cicigweike is on a distinguished road
Hi Sorojchi,
Please connect the girl who had sold you this machine.
she will connect engineer to help you solve this problem.
It is hard to repair a machine by words only, so please send video
to her, we will help you repair it as soon as possible.
Cici
Need Help!- versa laser, laser engraving cadmaniac Laser Engraving & Cutting Machines 27 04-25-2010 03:30 PM
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 9 11-27-2007 01:31 PM
Supply Laser cutting machine and Laser engraving machine sherryguo Product Announcements & Manufacturer News 5 11-27-2007 08:47 AM
Laser/laser machine basics ? Konstantin Laser Engraving & Cutting Machines 2 08-27-2007 06:30 PM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 03:39 PM
