Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-13-2008, 01:37 PM
Huahahahahaha is on a distinguished road
Marking Stainless using CO2 laser 60 Watt
Hello Friends,
i have something news to share.
Today i could make some marking on stell and stainless Steel using my laser.
just coat that steel using etching chemical.
After that put it on laser.
i using speed 5 power 40. ( usually use that for cutting acrylic )
have good result with that.
when i use engraving mode, my speed 200 power 50 distance 0.05
but still don't have good result, the marking gone when i scratch with nail.
Please share your comment and your result with your laser.
Regards,
Huahahahahaha
Rabbit Laser 60 Watt.
Old 09-14-2008, 12:45 PM
SkipW is on a distinguished road
Which etching chemical did you use? Did you use Cermark or the Brasso/clay mix?
Can we see a picture?
Skip
Old 09-14-2008, 12:57 PM
Using Ferric Chloride and Brasso
i will post the pic tommorow, when i go to workshop.
Old 09-15-2008, 10:05 AM
i still don't have time to try laser etching again.
but i found the problem, why the result is bad.
i not cover all area perfectly with that solution. ^_^
because i just want to try that time, and not hope will success.
this is the pic.
in the outline, i use configuration for cutting acrylic. ( low speed, high power )
the letter, using graving configuration.
btw, i also could colouring the acrylic, without losing its transparancy effect.
Old 09-15-2008, 07:52 PM
That is a good start.
Maybe you would have to laser it 2 times to make it darker?
Skip
Old 09-17-2008, 04:00 PM
spacer777 is on a distinguished road
hi, i used thermark metal marking solution on stainless steel, the graphics and text were unsurpassable, it is fantastic and my customers are very pleased with result
Old 09-25-2008, 01:02 PM
muqtadir is on a distinguished road
Hi
I am using Cermark (for stainless steel) and getting excellent results and give black color with permanent mark. Can go by sand paper.
Old 09-25-2008, 02:39 PM
i know i could using cermark or thermak, but it's to expesive for me.
And couldn't find in here.
so i just want to inform another cheap solution.
^_^
Old 12-01-2008, 06:27 AM
casa verde is on a distinguished road
see page Tecnocorte in spain
http://www.tecnocorte.net/
http://www.tecnocorte.net/quimico.htm
they sell twenty-eight (28) different products to mark in black or colors on metal, ceramic, glass and plastics
This water based products which allows for a fast drying time and easy clean up that are easily applicable with paintbrush or foam brush
Also if adecuated diluted with water, are used in Spray gun, airbrush, Bird applicator, draw down bar.
Old 12-01-2008, 09:23 AM
lasermax10 is on a distinguished road
Hello, good morning , are there anybody ?
  #11   Ban this user!
Old 09-21-2010, 03:18 AM
kelvinguo is on a distinguished road
Please using our semiconductor side laser marking machine for marking on stainless , it can work very well with many metal material non metal material . There are 50W and 75W of laser power with Length of laser wave:1064nm , Marking scope: 100x100mm - 300x300mm, Min line width: 0.015mm, min character: 0.15mm, Marker line speed: ≤ 7000mm/s, Mark deepness: ≤0.4mm, Repeat precision: ±0.001mm, Power supply: AC220V 50Hz/, Operating temperature: 10-35°c, moisture: 5-75°c, Cooling style: closed loop water cooling, Demension: 1300mm*850mm*1160mm . If you're looking for laser marking machine to purchase ,please feel free to contact me directly at kelvinguo@syfos.com
  #12   Ban this user!
Old 09-21-2010, 10:47 AM
Dear friend
We know your semiconductor machine type, it lets to engrave over metals , now we have development special inks that let engrave over metals too, using CO2 laser machine cheaperof low power 25 w , marking strong black color or marking a deep over metals .
Also we have several color to engrave over anodized aluminum, ceramic, glass and plastic .
You can see it on http://articulo.mercadolibre.com.ar/...o-en-color-_JM
or on http://us.my.alibaba.com/product/pro...tm?id=11747085.
Thanks very much .
LaserMax10
Synrad 50 watt laser KTP Laser Engraving & Cutting Machines 26 11-11-2011 03:38 AM
Anybody know what a laser marking machine costs? squale General Metal Working Machines 8 08-28-2011 11:37 PM
Laser Marking Clear Anodized Al petriej Engraving Machines 12 10-04-2010 07:16 PM
Artcut JSM 40 watt laser ccroyscuba Laser Engraving & Cutting Machines 11 09-17-2009 06:40 PM
laser marking machine for metal JennyYin Product Announcements & Manufacturer News 0 07-06-2007 12:07 AM
