| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
#13
| Hi, LaserMax10 I can't access to your alibaba website correctly and other site , which I don't know that language . please tell me the marking speed , marking thickness, min charactor and min line width ,etc. thanks. Kelvin Guo |
#15
| Alibaba Laser Engrave Color Marking Products (Atrex Engineering Co. Ltda ... Atrex Engineering Co. Ltda. is an Alibaba supplier that manufactures Laser Engrave Color Marking Products in Argentina. Laser Engrave Color Marking Products ... http://www.alibaba.com/catalog/11747..._Products.html - 29k - http://us.my.alibaba.com/product/pro...tm?id=11747085 atrex_ingenieria@argentina.com / lasermax10@argentina.com |
#16
| Metals and Alloys 1. ATREX 7007® generates a dark mark, on: Stainless Steel and Common Steel. 2. ATREX 7011® generates a dark mark, on: Aluminum and alloys. 3. ATREX 7015® generates a dark mark, on: Chromium-plated and Nickel-plate 4. ATREX 7031® generates a deep, white, or dark mark, on: Stainless steel 5. ATREX 8033® generates a dark mark, on: Titanium Depth Engraving : The ATREX 7031 product allows Deep Security Engravings, gravure in steel or stainless steel, cannot be erased without destroying the surface of the metal and they are useful for the quick and permanent identification of weapons and steel tools. They can also be used like base for beautiful effects of color contrast for a subsequent passing with the same o another dark product. |
#18
| This is the only option for a low power CO2 laser. It does not create an engraving/etching mark so has no depth for you to fill, but depending on the pigment in the chemical additive you will get a visible mark that is unable to be removed without physically damaging the base metal. If you want to create an etching, Nd:YAG or Yb:YAG will work well, you can also use a chemical etching process (with laser cut mask), or the simplest would be a CNC router with engraving bit. Zax. |
#19
generates a 0.1 mm deep, white, or dark mark, on: Stainless steel. It was not development to be fill manually with other paint. It was made to engrave a deep ; if you look for permanent black mark we have codige 7007/7011/7015. Of course to create an etching, Nd:YAG or Yb:YAG will work well, you can also use a chemical etching process (with laser cut mask), or the simplest would be a CNC router with engraving bit. It is think to let work with low power CO2 laser machines , getting more option to work with this type of laser machines. (not only cut and engrave soft materials) |
#20
generates a 0.1 mm deep, white, or dark mark, on: Stainless steel. It was not development to be fill manually with other paint. It was made to engrave a deep ; if you look for permanent black mark we have codige 7007/7011/7015. |
| Synrad 50 watt laser | KTP | Laser Engraving & Cutting Machines | 26 | 11-11-2011 02:38 AM |
| Anybody know what a laser marking machine costs? | squale | General Metal Working Machines | 8 | 08-28-2011 10:37 PM |
| Laser Marking Clear Anodized Al | petriej | Engraving Machines | 12 | 10-04-2010 06:16 PM |
| Artcut JSM 40 watt laser | ccroyscuba | Laser Engraving & Cutting Machines | 11 | 09-17-2009 05:40 PM |
| laser marking machine for metal | JennyYin | Product Announcements & Manufacturer News | 0 | 07-05-2007 11:07 PM |
