Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-06-2008, 09:32 PM
travislivid is on a distinguished road
What is the bottom line to cut sheet metal under 2mm
I have been reading posts for days and chatting back and forth with laser tube traders. I want to build a machine to cut mild steel and stainless less then 2mm. Alot of the lasers under 100w say they can cut sheetmetal but not specific on how thick. a couple kit suppliers say they have plans for 50w, 80w, and even 100w lasers I can cut sheet metal. A guy selling a 150w YAG laser told me 2mm sheet metal is no problem but I would have to focus the beam for it. I have seen other posts that say you need 200w, at the very least and more like 500w. A friend of mine built a laser engraver and said that to cut even thin steel I need 200w but that I could combine 2 lasers with a beam combiner and have enough power to cut steel. If I truly do need 200w, it seems like I can build 2 100w lasers way ceaper then finding a 200w+ laser and power supply without spending 10g's
Please weigh in. I am not too concerned with feed rate. Just need to know if there is any way possible to get a clean cut through thin sheetmetal with under 100w?
Thanks sooooo much
Travis
Old 09-07-2008, 06:44 AM
grzegorz1965 is on a distinguished road
I tried to cut steel (0.1 mm gilette) with 80W CO2 laser.
Poor results.Bad edge.
I think You should think about 200 - 400 W CO2 laser for non idustrial use.
Grzegorz
Old 09-07-2008, 07:47 AM
Does combining two 100w lasers sound like a reasonable thing to do?
Old 09-07-2008, 11:21 AM
MacGyver's Avatar
MacGyver is on a distinguished road
You do NOT want to get into the area of combining beams... you'll spend a lot of time attempting and fail int he end.
YAG is going to be much easier to use for cutting metal than CO2, as you'll need probably 5-10 times less power. The wavelength of YAG lasers are in the right range for being absorbed by metal.
Hi-TecDesigns.com -- Automotive Lighting Systems
Old 09-07-2008, 02:11 PM
Derek Kern is on a distinguished road
Metal Cutting Systems
traveislivid-
We are cutting 2.3 mm mild steel and 1.7 stainless with our 150 watt CO2 laser systems. Very nice edge quality. PM me for more information.
Derek Kern
Kern Electronics & Lasers, Inc
1-888-660-2755
www.kernlasers.com
Job Opening CNC programmer - Sheet Metal scotia Employment Opportunity 0 06-11-2008 06:49 AM
Job Opening CNC operator – Sheet metal scotia Employment Opportunity 0 06-11-2008 06:46 AM
Sheet metal router bit cxixer General Metal Working Machines 3 03-07-2008 10:17 AM
cheap sheet metal MBG General Metalwork Discussion 1 03-04-2005 01:35 PM
Ok so what is the bottom line? WallCrawler CNCzone Club House 8 06-19-2003 10:51 AM
