Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-28-2008, 08:50 AM
dar303 is on a distinguished road
Any YAG experts around?
I may get a used YAG-head really cheap.
The laser is an Spectron Laser Systems and is marked "180W CW / 35mJ"
I'ts just the head with engraving galvos and I'm wondering about the needed chiller and power supply data for a YAG of this size.
I realize this is a major project to undertake so I need some more information. If I end up trying to get it going it won't be to make any profit from it, just for fun and learning!
Regards
/Daniel
Old 08-28-2008, 10:48 AM
MacGyver's Avatar
MacGyver is on a distinguished road
The head itself is going to need some serious power... think in the range of 100A at a few tens of volts.
Hi-TecDesigns.com -- Automotive Lighting Systems
Old 08-30-2008, 06:51 PM
mexico.redsail is on a distinguished road
A CW yag laser uses arc lamps that run on anything from 180 to 340 volts at 40 to 80 AMPS
plus the chiller used will need deionized water becouse the watter will be in contact with the lamp and Voltage terminals.
you might get by using a ION laser PSU
i can help you if you decide on taking the project.
Eduardo
Originally Posted by dar303 View Post
Regards
/Daniel
Old 08-30-2008, 08:31 PM
MacGyver's Avatar
Hmmm, I thought SLS used direct drive laser diodes in their systems, not flash lamps. If it's flash lamps, use Redsail's specs... if it's diodes, use mine.
Old 08-31-2008, 09:20 AM
you are also correct, it could be diode pumped, but for the rated power i dont know.
regards
Eduardo
Old 08-31-2008, 09:28 AM
I got these pictures:
the laser:
http://img352.imageshack.us/img352/4387/yaglaserrh7.jpg
The lamp housing & rod:
http://img175.imageshack.us/img175/9605/pumphusvk4.jpg
Old 08-31-2008, 01:27 PM
Thanks for the offer Eduardo! I will know if I get the laser in about a week.
???? For The Gear Experts Alex Westling General Metalwork Discussion 1 02-01-2008 09:42 PM
Need Help from the experts studysession DIY-CNC Router Table Machines 1 01-08-2008 08:00 PM
bearing experts i need your help? MaxQ General Metalwork Discussion 3 06-22-2007 04:26 PM
Any AB PLC experts? jderou General Electronics Discussion 5 11-11-2005 07:14 PM
any pic experts? posix PIC Programing / Design 27 07-01-2005 02:27 AM
