Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-22-2008, 04:35 PM
CARTOGATE is on a distinguished road
Laser won't fire
Please help me.
I've tried to update the firmware to my laser engraving machine (MPC6515 controller) to the latest that I found in the LaserCut 5.3 pack. First update didn't work, the pad froze at "System starting", then I retried and it started.
Everything works fine except that I can't fire up the laser. Neither from software or pad. I've tried everything, even downgrading firmware to the old original one and older than that. Nothing worked?
What can it be? What are the causes? Software or mechanical?
Old 08-24-2008, 09:41 PM
lamicron is on a distinguished road
First check all this:
Is the power supply working?
Cant you see the laser firing inside the tube?
Did you try to reinstall the software? ( remember the 5th reinstall is the best... ) Most of us have reinstalled it a lot of times...until it worked correctly.
E stop working?
and, let us know
Luis
Old 08-25-2008, 12:51 AM
Yes, the power supply is working since I can move the laser and all. Unless there's a separate power supply for the laser? I don't know about that.
I don't see the laser firing up in the tube and I've reinstalled the software lots of times.
Thank you for your reply.
Old 08-25-2008, 02:22 AM
I managed to make it work. I've uninstalled the LaserCut 5.3 software and reverted to the old firmware and LaserCut 5.1.
Thank you for your help.
What Fire Precautions Do You Use? diarmaid Polls 27 04-12-2010 10:07 AM
using gas to stop fire on 3040 laser? StarLoc Laser Engraving & Cutting Machines 0 06-25-2008 01:20 PM
Smoke and fire...yes FIRE! fatal-exception Gecko Drives 13 01-25-2008 01:58 PM
Fire Rings millerrocks06 Product Announcements & Manufacturer News 8 03-31-2007 03:08 PM
