Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-07-2008, 10:38 AM
funidea is on a distinguished road
Coherent 150 watt
The Coherent 150 watt has a 6 inch long tube out the front that changes the beam from a diamond to a circle. This tube is called the "beam shaper". Coherent has done a nice job on this laser as the output is nearly 200 watts of cutting power. I have seen this slice through nearly 1/8" steel at KERN laser systems. www.kernlasers.com. Other laser manufactures are using 100 watts and Universals 120 watt. The size weight ratio is good for the power and can be mounted in several configurations. You can move this laser or use it on a flying optic setup. Coherent's 150 has a peak pulse of nearly 500 watts during initial pulse which is great for cutting thick materials. I've seen this laser up against others like Synrads 200watt but even though Synrads power is higher the Coherent 150 will cut faster because of the mode. Good mode or beam concentricity is key. If i was to buy a laser or build one Coherent 150 would get my vote.
Old 08-07-2008, 11:13 AM
MacGyver's Avatar
MacGyver is on a distinguished road
Okay... what was the point of this post again?
Hi-TecDesigns.com -- Automotive Lighting Systems
Synrad 50 watt laser KTP Laser Engraving & Cutting Machines 26 11-11-2011 02:38 AM
50 Watt CO2 kdoney Laser Engraving & Cutting Machines 13 06-29-2007 03:12 PM
60 watt engraver- opinons? replicapro Laser Engraving & Cutting Machines 10 05-14-2007 07:41 PM
What will 50 watt cut? CNCadmin Laser Engraving & Cutting Machines 2 04-11-2007 03:06 PM
1400 watt UPS's dneisler General Electronics Discussion 5 01-22-2007 08:20 AM
