| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| I asked that question myself a month or two ago. Never did get an answer. I've got 5.0 and there is a bug in that version where if you uncheck the "Auto Datum" (home) check box in the machine options, you have to change the start speed parameters or else you can't send files to the laser without the software crashing. Maybe that is one of the bugs that are fixed in 5.1 but I don't know for sure. That's the only problem I've ran into with 5.0, other than the 2bit (black and white only) bitmaps. Sure would be nice if they came out with a version that would do 8bit grayscale like most other laser engravers. Skip |
| Just a thought about your bug - maybe you should check that your start speed is less than your datum speed and or equal to the constant speed. I had an instance when I was getting started that I had my cutting speed less that the constant speed and the machine would just not run. When I took my start and constant speeds down below the figure it was fine - as I say just a thought? |
| It's fixed. When it happened, I emailed WK Laser about it and they had me change the start speed and that corrected the problem I had to drop the traverse start speed down to 8. Now when I traverse the laser head, it starts out at 8 (slow) and after a few seconds it speeds up. That actually works well for fine tuning the head position when needed. I've been looking online to see if I could find out who actually makes the LaserCut software and to see if they had a website. I can't find anything. I have even asked WK Laser if they knew what the difference was between version 5.0 and 5.1. I didn't get any reply. Must be a state secret or something. Skip |
| Hi, The first difference between 5.0 and 5.1 is you will need a different dongle . The two do not like to run on the same p.c as they corrupt each other. the 5.1 looks better and still has some issues it is ment to take corel x3 but I cant confirm this. The main advantage is the output isw on the main screen allowing you to select and adjust without too much messing about. If you want us to try somthing I will for you to see if it works. Thanks Chris Oh you also have to upgrade firmware to allow the main board to run with it.# Thanks |
| Thanks for the update - I was a bit reluctant to upgrade and I am glad I waited - Its a bit of a problem to get a new dongle though - I will have to investigate - Are you able to post a screen shot of the page where the changes to the software are or wouldnt we notice any difference? |
![]() Have a look at: http://www.step-servo.com/english/le...page/first.asp 'Cant see anywhere there to get Lasercut, but they do have manuals for it, and make the controller boards that Lasercut runs on. |
#11
| Hi, someone speak spanish?. Because i dont speak english very well. Anywere, i need help with lasercut 5.1. I reinstall windows because a virus, then reinstall lasercut 5.1 without problems., and when i run the progran appears "open motion card error", and the program doesn´t work. Thanks to someone who answer my question. I don´t know what to do My name is Anibal, from Mar del Plata, Argentina. |
#12
| Hola Anibal, uno de los afiliados me pidio que te contestara la pregunta, hace rato que no entro al foro. Mira estos software chinos molestan un poco pero son muy buenos cuando ya los tienes trabajando, pero.... reinstala las veces que sea necesario hasta que funcione bien , nos ha pasado a todos y en vez de pelear con la instalacion reinstalamos. NO hay quinto malo dicen por aca... la quinta instalacion es el numero de la suerte.. te envio mi correo por mensaje privado, luego que reinstales si tienes mas problemas me avisas y desde el foro te ayudamos. Luis |
| Lasercut 5.0 & coreldraw problems | durtydogg | Laser Engraving & Cutting Machines | 41 | 05-16-2010 02:48 PM |
| LaserCut 5.0 and Windows Vista? | glintid | Laser Engraving & Cutting Machines | 17 | 12-09-2009 03:07 AM |
| Lasercut software | terry32506 | Engraving Machines | 3 | 07-27-2009 11:25 PM |
| Not really a log... LaserCut router | Guldberg | CNC Wood Router Project Log | 22 | 07-04-2008 06:51 AM |
