Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-26-2008, 09:26 AM
tklock is on a distinguished road
Smile Looking for some Help Optic Lens
I purchased a artsign JSM40 a while ago, Like everyone I was haveing some troubles with getting it aligned. Last night I was checking things over and I noticed that one of my Mirror/Optic lenses were cracked, when I took it out it broke into pieces. Does anyone know what the size of theis Lens is, or where I can purchase a new one. I would appriciate any input thanks
Old 03-26-2008, 10:14 AM
MacGyver's Avatar
MacGyver is on a distinguished road
I believe they're 1/2", but I'll have to check when I get home.
Hi-TecDesigns.com -- Automotive Lighting Systems
Old 03-26-2008, 12:00 PM
Thanks, I dont know anything about this, not even sure if its called an optic mirror lens. I am just learning how to use this. I have been searching for anyone who sells these but I have not been very successful. Thanks again
Old 03-26-2008, 07:40 PM
MacGyver's Avatar
Are you looking for the lens or mirrors? Plenty of sources... Edmunds Optics will probably prove the easiest for you. Look for ZnSe lenses and gold-coated mirrors with AR coatings.
Old 03-26-2008, 07:50 PM
I am not sure, what are the differences, It is a gold plated disc, I think it is 3/4" across, But I am not sure if that is the way to measure it, I am not sure the thickness, Sorry, I am not fimiliar with all the working componants, This is a new venture for me.
Old 03-26-2008, 08:13 PM
I checked out Edmuns, I am lost here I dont know what wave length or size ??? Very confusing, I am not sure of the size, The company that I bought it from has not replied with any information, I guess buying china products has its down falls. Thanks for the help
Old 03-27-2008, 07:11 AM
MacGyver's Avatar
The "gold-plated disc" is a mirror... pick up another one from Edmunds, same diameter. The thickness will be roughly the same, but it's not critical. You're looking for something with an AR coating in the 10um range.
Old 03-27-2008, 07:27 AM
Thanks,
Does the size sound about right ?? 3/4 ?? It is about the size of a Nickle. Maybe a bit smaller. Thanks
I checked Edmunds again, Not sure where to begin there are a lot of choices, Flat, Not sure the wave length ?? I am very geeen to this, What is a 10um ?? Sorry to sound a little green here, just learning. I also diddnt see a 3/4 size, I may be looking in the wrong place. ???? Just confused here ???
Old 03-27-2008, 10:45 AM
MacGyver's Avatar
Measure the mirror to be sure... 10um is the wavelength (also look for CO2, they will typically list it as an application).
Old 03-27-2008, 05:39 PM
ok, did that, Just still not sure which one is the right one on Edmunds. It measures at 3/4" across and 1/8" thickness which is about 20mm, I looked in edmunds but I am lost as to the exact one that I should get, I just don't want to get the wrong one. Thanks for your help.
Mirrors and Lens Furlan Laser Engraving & Cutting Machines 1 03-30-2007 08:52 PM
co2 lens info frafab Laser Engraving & Cutting Machines 3 07-18-2006 03:27 AM
Focus lens jtj30 Laser Engraving & Cutting Machines 1 05-03-2006 10:10 AM
Where to buy lens? medved Mechanical Calculations/Engineering Design 5 12-30-2005 02:49 AM
G-Code for a lens PEU G-Code Programing 15 12-22-2005 04:39 PM
