Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-19-2008, 01:05 AM
occam999 is on a distinguished road
Omnisign alternative software recommendations?
I've recently purchased an Onnisign Pro 500 laser engraver/cutter from www.reddotinternational.com and I wonder if anyone has experience/recommendations for software other than Moshidraw?
Also, is it possible to use this device with an HP-GL printer driver? I guess I should just try it!
Thanks for any input.
Regards,
Dave.
Old 03-04-2009, 02:44 AM
Omnisign Plus PRO 500 - any compatible drivers?
Hi - I'm still wondering if there is an alternative to Moshidraw?
Thanks.
Old 03-05-2009, 02:18 AM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
Moshi...ugh!
Have a look at Solustan's LinkMotion. I
I've no idea if it will work for your machine (since you didn't say what it is) but you could ask the engineers there.
http://www.solustan.com/products
Disclaimer: I'm a customer and use LinkMotion on my laser.
Bob
Old 03-05-2009, 03:17 AM
Hi Bob,
Thanks for your reply. I did mention that the machine was an Omnisign 500 Pro (from http://www.reddotmachinery.com.au/pr...ngraver_B.html)
I now know it won't work with a HP-GL printer driver (apparently the controller only recognises a limited subset of HP-GL commands), and it seems from further research that the best bet is to replace the motor controller boards with some more standard hobby-cnc units that can be driven by EMC2 or similar.
Still, if anyone knows of a good software alternative, I'd be more than happy to hear about it!
Bob
Old 08-08-2010, 06:32 PM
Sola is on a distinguished road
Omnisign Plus PRO 500 II
Hi
I have a Omnisign Plus PRO 500 II. which runs off corelDraw.
Am on 2nd tube (3rd actually after a faulty replacement was set)
Have been using mine for about a year and a half not sure if i can be too much of a help but would be good to have a chat to some people about it.
Cheers
Omnisign problems, lamicron Laser Engraving & Cutting Machines 2 08-18-2009 04:19 AM
Cadcam software recommendations?? Chevy-SS General Metal Working Machines 22 10-23-2007 08:10 PM
Software and controller recommendations for ROUTER Scott Evans Commercial CNC Wood Routers 12 07-10-2007 12:26 AM
Plasma 'tabbing' software recommendations? vladdy CNC Plasma and Waterjet Machines 1 02-16-2007 08:08 PM
Software recommendations anyone ?? DJ Morrow General CAM Discussion 5 12-30-2003 07:50 PM
