Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-17-2008, 08:03 PM
blue^ray is on a distinguished road
Just been thinking wouldnt it be great to have a laser.
Ive been hearing good things about hklasers and ive been chatting to the staff on msn, and I am being told their larger lasers dont even cut perspex greater than 7mm.
Now where are the lasers that cut aluminium ect?
Was looking to build some roller pinions and gears, for linear motion but require 100% accuracy with which I thought the lasers would be able to do.
What lasers actually cut stuff? the lasers at hklasers seem to be just engravers for what I want to cut.
What do you guys normally use them for?
Old 02-17-2008, 08:55 PM
Samax is on a distinguished road
Question
Hi, if you wanna have a laser, why not take us into consideraion? I think there must be one model suitable for you.
ID:	53665   Click image for larger version
Old 02-18-2008, 02:42 AM
Will_Laser is on a distinguished road
what sort of thickness are we talking here? And also, what about avilable space and budget?
Old 02-18-2008, 10:06 AM
MacGyver's Avatar
MacGyver is on a distinguished road
If you want to cut metal (not just etch), you need to be looking at YAG lasers, not CO2.
Hi-TecDesigns.com -- Automotive Lighting Systems
Old 02-19-2008, 07:03 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
Aluminium and copper are probably the hardest stuff to cut with a laser in the CO2 class as they just reflect most of the beam back. A laser machine in about the 3K-4K Watt range will cut 1 1/2" to 2" steel (correct me on this) but only cut about 5/8" aluminium plate if that.
The mirrors on my 35 watt laser to bend the beam around to where I want it are Aliminium so as you can see you probably won't be able to afford one in the class you want.
Unless you are rich and REALLY want one.
Rich.
I am not completely useless.......I can always serve as a BAD example.
Old 02-22-2008, 02:08 AM
GAWnCA's Avatar
GAWnCA is on a distinguished road
How would it work if you were to blacken the aluminum before cutting with the laser? Or, scuff the surface with sand paper? I'm not really rich but would like to be able to laser cut aluminum.
Rich.
Old 02-22-2008, 07:29 AM
MacGyver's Avatar
Google Cermark (there are others)... it's a paint-on material that will allow etching of aluminum (but not cutting). If you must cut, you need YAG.
Old 02-22-2008, 08:26 PM
SimonArthur is on a distinguished road
You should consider buying a waterjet cutter if you want to cut metal.
Or you could just make use of ours: http://www.bigbluesaw.com
Old 03-14-2008, 11:53 AM
GAWnCA's Avatar
How about building a water jet?
Old 03-14-2008, 12:12 PM
This comes up every now and then here and on other forums.
Building a waterjet could be quite tricky. You need very high pressure pumps, hoses and fittings, 30,000 psi and up. Plus a big catch tank, a system to mix the water and the abrasive, a nozzle, and specialized control software.
It's certainly possible to do, but I'm not aware of anyone who has made a DIY waterjet. You might be the first.
  #11   Ban this user!
Old 03-14-2008, 12:16 PM
GAWnCA's Avatar
Well, what I would like to cut is aluminum but I've read where the laser doesn't like the reflective surface. How would I overcome this problem with a laser? I only want to cut plat up to maybe 3/8" or so.
  #12   Ban this user!
Old 03-14-2008, 12:38 PM
You'll need a powerful laser.
Tracker CNC plasma cutting machines AdvanTech CNC Plasma and Waterjet Machines 44 05-31-2011 11:06 AM
Chineese Laser Machines and Tubes Laser Doctor Laser Engraving & Cutting Machines 16 09-14-2007 03:11 PM
Engraving photographs with CO2 Chinese laser machines? GDP Laser Engraving & Cutting Machines 7 08-19-2007 08:01 PM
CNC Laser machines CNCadmin Laser Engraving & Cutting Machines 7 06-25-2007 11:49 AM
Sizing of CNC Machines For plywood cutting dswink DIY-CNC Router Table Machines 5 05-17-2007 02:50 AM
