Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-20-2008, 04:09 PM
ccroyscuba is on a distinguished road
Artcut JSM 40 watt laser
Does anyone currently have one of these, and you are expierencing stepper motor skipping, if i run mine over 1 on the engraving and over 10 on the scanning, it skips all over the place, any thoughts welcome....
Old 01-10-2009, 09:40 AM
sgrtecnica is on a distinguished road
Hello
I wanted to know if anyone has pictures of the connection of the laser source of 60 wat is the model myjg 60wat?
Old 01-11-2009, 11:27 PM
LaserNOT is on a distinguished road
My rabbit is the same model with a different name, My machine skips on anything over 2, and 8.
Figured those were the max settings anyway...?????
Old 01-12-2009, 07:32 AM
zax15uk is on a distinguished road
Actually that was an old post, but yes I have the same machine and 2 for cut / 8 for scan are about the max numbers - I can push 10 for scan ok and 12 just works but sometimes skips a few steps depending where on the machine.
Old 09-17-2009, 09:40 AM
tintaroja is on a distinguished road
Please anybody could help me
I bougth a Laser engraver mchine JSM40, but it doesnñt work well. I dont understand the program and the manual is not esecified.
Help me please
Old 09-17-2009, 11:23 AM
What problems are you having?
If you want to send me your email via PM I can forward you some information.
Zax.
Old 09-17-2009, 12:10 PM
Smile
I live in Ecuador. I bougth this macine in internet.
I don´t know how to calibrate the laser for diferents materials. Some times the cut line is very thick.
Sometimes the laser is moving too that the drawings are distorted.
Please help me
Old 09-17-2009, 01:33 PM
nobacoutinho is on a distinguished road
Ola tintaroja
Favor clicar sobre o apelido de Zax... Despues clique sobre PM e envie su email a ello. Esto es a private message. Yo tambiem tiengo una JSM-40 e aprendi mucho com Zax, lendo sus posts aca em CNCzone. Elo es el "papa" quando se refire a jsm-40.
To Zax:
My english and spanish are not very good.
I said to tintaroja how to send you a PM.
"Please click in Zax nick name and after click in -send a PM - and send him your email. This is a Private Message. I have too a JSM-40 and learn lots with Zax, reading their ( your ) posts here in CNCzone. Zax is the Pope in JSM-40 area here in CNCzone.
Old 09-17-2009, 01:46 PM
Obrigado
Zax.
Old 09-17-2009, 01:55 PM
If you are cutting, the speed should be set at 1 or 2 max.
For engraving (scan) you can use 1 to 12, with 8-12 being usual.
Of course you must also adjust the power for different materials also.
What materials are you using, and for cut or engraving?
Zax.
Please help me
  #11   Ban this user!
Old 09-17-2009, 03:51 PM
I use leather, rubber, glass, cork for engraving.
For cutting I use paper, raft, cork, acrylic.
Where can I adjust the power? because only can adjust the scan speed and cut spped .
Which means Cut delay , scan delay and gap delay????
  #12   Ban this user!
Old 09-17-2009, 05:40 PM
Power is adjusted on the machine, using the 'Current Regulator' knob. If you turn it fully counter-clockwise the power will be 0, each turn clockwise would be 10% of the power.
The delay settings allow time for the beam to turn on before the machine moves. Defaults of 1ms should be ok.
Line gap is used when engraving to set the DPI. A setting of 0.05mm is 508dpi (25.4 / scan gap = DPI).
Cork is very difficult to cut, it absorbs heat too well and burns. You can burn an image onto it but it will smudge unless you seal it.
Zax.
Synrad 50 watt laser KTP Laser Engraving & Cutting Machines 26 11-11-2011 02:38 AM
50 Watt CO2 kdoney Laser Engraving & Cutting Machines 13 06-29-2007 03:12 PM
60 watt engraver- opinons? replicapro Laser Engraving & Cutting Machines 10 05-14-2007 07:41 PM
What will 50 watt cut? CNCadmin Laser Engraving & Cutting Machines 2 04-11-2007 03:06 PM
1400 watt UPS's dneisler General Electronics Discussion 5 01-22-2007 08:20 AM
