Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-08-2008, 05:39 PM
bisjoe is on a distinguished road
Cutting Stained Glass
Has anyone tried vector scoring stained glass on the laser instead of using the usual hand cutting wheel? I tried it and it did work for straight lines and gentle curves, but for a more drastic curve it will break randomly. I was using speed 25, power 100, Frequency 5000 at 600 dpi on my 45 watt. Even tapping after scoring didn't work.
Old 01-12-2008, 11:55 AM
kodsnoba is on a distinguished road
To cut tight curves using hand cutter you must not make only one cut at desired cutting line, you have to make multiple circular cuts which are "straighter" (not too tight, pieces shaped as crescent moon). Its like taking small bites. After each cut you break away piece of glass with pliers until you reach your desired cutting line.
Maybe this aproach will work with laser. Make multiple scoring lines in glass, and break away little by little.
Pino
Old 05-06-2011, 06:32 AM
yunusmamoo is on a distinguished road
Cutting glass with CNC machine, which is better?
Scoring by laser or scoring by tool ?
Old 05-06-2011, 07:44 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Scoring with a tool is better than scoring with a laser for glass.
The tool produces a 'V' shaped break line whereas the laser produces a 'U' shaped break line.
There are other differences but I have tried both methods and for me the tool wins hands down.
Tweakie.
CNC is only limited by our imagination.
glass cutting table cristian gabor Mechanical Calculations/Engineering Design 5 05-29-2009 01:51 AM
Laser Cutting Glass boxxer_boy Laser Engraving & Cutting Machines 8 08-04-2007 09:05 PM
Need Help Cutting Glass!!! ariel 1 Glass, Plastic and Stone 19 07-10-2007 01:53 AM
Cutting glass SRT Mike General Metalwork Discussion 1 05-15-2007 11:13 PM
Glass cutting gabi68 DIY-CNC Router Table Machines 7 11-11-2006 08:34 PM
