| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I've been using silicon reflective mirrors for my C02 laser and I'm considering going to copper, the reflectiing is slightly better but is their any special care to maintain the mirrors will I see a big improvement to total power out-put?
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| In order of reflectivity (high to low): AR-coated copper, coated gold, and dielectric enhanced silver on silicon. If he mirror is properly coated, there should be no maintenance required other than occasionally wiping the face gently with a cleaning cloth.
__________________ Hi-TecDesigns.com -- Automotive Lighting Systems |
| dragging a acetone lens tissue across them is typical cleaning. When they get alittle heavier smog, a good copper polish (like brasso) gentle rubbed to break the haze then acetone cleaning. A protected bellow cover over the beam path with a positive pressure blower guards against smoke and contaminates. It also extends mirror maintenance intervals and life. Watch for sweating in high humidity. Last edited by laser3kw; 12-23-2007 at 02:00 PM. |
| Paul, at your power levels you shouldn't see any performance difference between the different mirror types. I would just go with whatevers CHEAPEST. Laser.Tech
__________________ If it's already been done, then it ain't NO FUN! |
| Nickel Silicon-Carbide (Nikasil) | crayner | Metal Finishing and Plating | 5 | 01-19-2008 10:35 PM |
| Silicon Sealant work with coolant?? | Rodm1954 | Benchtop Machines | 5 | 11-03-2007 03:15 AM |
| Silicon Nitride Milling Inserts? | ajl6549 | General Metalwork Discussion | 10 | 02-12-2007 08:23 AM |
| Machinist looking for work in Silicon Valley | Grinding Guy | Employment Opportunity | 0 | 10-29-2006 05:07 PM |
| Silicon Bronze | drakesis | Casting Metals | 9 | 02-23-2006 05:18 PM |
