| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Hi oljeg, A 100 watt Synrad laser costs $16,000USD so I would think a 200 watt one would be around $32K - $36K plus the 80 amp power supply which will add several hundreds of dollars to the cost. Rich.
__________________ I am not completely useless.......I can always serve as a BAD example. |
| Hello, did anyone gave laser tube (Sinrad model 48-1) on refill at lokal gas service? What is the procedure - important informations to make proper refill? I know it should be used CO2 gas. With how many bars (unit of pressure) should be filled? What installation - slip road is used? Have an old GCC Laser Pro model L-12 (12 W) made in 1999. Think this information would help lots of people. Thanks |
| Mery, If only it were that simple. The Synrad 48-1 tube contains a mixture of gasses 5% CO2, 15% Nitrogen, 80% Helium and maybe others and it is in the tube at below atmospheric pressure. Tweakie.
__________________ CNC is only limited by our imagination. |
| The local gas service can probably provide bottles of 'laser mix' gas for a flowing gas laser but re-filling a Synrad tube is a different matter. The exact mix is proprietary but the base is as Tweakie mentioned, I would check with a local Synrad supplier or perhaps Litografa has a suggestion. Zax. |
| Synrad 50 watt laser | KTP | Laser Engraving & Cutting Machines | 26 | 11-11-2011 02:38 AM |
| Synrad vs. Laser Tubes + PS Questions | m_constrained | Laser Engraving & Cutting Machines | 25 | 12-01-2010 10:52 AM |
| bad laser tube | CNCadmin | Laser Engraving & Cutting Machines | 40 | 07-03-2007 10:23 PM |
| Synrad CO2 Laser available on Ebay | nelsonzjax | Laser Engraving & Cutting Machines | 0 | 12-07-2006 02:50 PM |
| Synrad 10W Laser Available on Ebay | nelsonzjax | Laser Engraving & Cutting Machines | 0 | 12-07-2006 01:36 PM |
