Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-20-2007, 12:01 PM
moos is on a distinguished road
MPC03/dedicated software 5.0
Hi everyone.
I am new here and to Laser cutters so I want to share my difficulties with you guys.
The problem is that the cutter can't/won't do 1:1
Scaling/resizing is not an option.
See if I import a .dxf file e.g. a 25mm in diam. circle the machine cuts it about 15mm in diameter
Evenso when engraving. It cuts a straight line or put carbage on the workpiece.
I've read some post about bad soldering points on the card.
I reflowed mine without any solution.
Installing the card was not a problem the first time (tried every empty PCI slot to solve this problem)
Btw, the card, software and driver came with the machine.
Am I doing something wrong or do you guys say try a 3rd party software that can control the MPC03 card?
Please help.....
Regards,
Moos
Old 11-20-2007, 12:55 PM
MacGyver's Avatar
MacGyver is on a distinguished road
Sounds lke you need to change the number of steps/inch setting... not a hardware problem, only a software setup issue.
Hi-TecDesigns.com -- Automotive Lighting Systems
Old 11-20-2007, 07:24 PM
lamicron is on a distinguished road
Moos , open your machine settings in the software, in the z axis and y axis , look for the pulse unit (maybe on top of the page) at the side of the numbers there is a box with little dots, click there, if you change that numbers you 'll get diferent moving distance per turn of the motors, then try to cahnge the numbers and measure again, that way you can get to the perfect size. Dont you have the manuals??
Old 11-21-2007, 02:24 AM
Thanx for the input.
"open your machine settings in the software, in the z axis and y axis ,..."
I asume you mean the X and Y axis?
I do have the manuals but with bad english
Ok, I found out the settings in the program, but it differs from yours (see attachment)
Anyway I've changed these and voila!...a perfect 25mm circle.
Except for now when cutting a retangle...the longest line is always shorter than the input no matter if I cut it horizontal or vertical.
Do I still need to change a setting?...see pdf.
I also got a sorta disc tool with the machine, is this tool used for getting the right height from workpiece to the nozzle? It has an adjustable inner wheel also.
Again this is not clear in the manual.
Moos
Old 11-21-2007, 03:03 AM
Thanx for the input,
I did a post reply but dunno what happened..seems it dissapeared
I do have the manual but in bad english.
Ok, I found out the settings in the program but it differs from yours..see attachment.
Anyhow I've changed these....and voila...a perfect 25mm circle
Except for now when cutting a retangle, the longest line always is shorter no matter when cutting horizontal or vertical.
Is there another tweak or setup for in the settings?
I also got a sorta disc tool with the machine. Is this tool used for the right height from workpiece to nozzle? It als has an adjustable inner wheel.
Again, no clear instruction for this tool in the manual.
Moos
Old 11-21-2007, 05:19 AM
svenakela is on a distinguished road
Moos
It got caught in the spam-filter.
Old 11-21-2007, 05:47 AM
Sorry, the x and Y axis is rigth,
The input in my machine for pulse is 6400, dont remembere the each length input.
But you can do the same with the steps for the rectangle,in the machine software draw a 100 x 100 mm box (or any size) and change parameters until you get the samne size in the cutting, I only make ltiny lines to get the real measure, you can do it very exact. If you want, send my your mail by private message and i'll send you the manuals, I have a collection of it.. ( also chinese softwares) Thats not a big deal,.. umhhh...
What is the brand and size of your machine?
Luis
Old 11-21-2007, 06:16 AM
lamicron,
sent you a PM....
Moos
LC12080, StepServo MPC03 and control software MicheleZicchino Laser Engraving & Cutting Machines 8 11-12-2010 04:25 AM
Mistake with Laser Machine (MPC03 Controller) rom1n Laser Engraving & Cutting Machines 8 07-30-2007 08:22 PM
MPC03 and MPC05 movement cards lamicron Plasma, EDM and other similar machine Project Log 0 07-26-2007 07:46 AM
CNC Web Browser (Dedicated to CNC) Switcher CNCzone Club House 5 12-04-2006 10:21 PM
Combos or Dedicated JSS Shopmaster/Shoptask 8 02-15-2006 02:53 PM
