Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-22-2007, 06:22 PM
Mrebeiro70 is on a distinguished road
Exclamation 40 watts not enough to cut 1/32" plywood?????
HX3040a from Rabbit.
I finally got my tube in and mirrors aligned, but now I can't seem to cut anything but cardstock and that's using 75 percent power.
I had it at 100 percent power and it just barely burned through the 1/32" plywood leaving about a 1/16" kerf. Am I doing something wrong or did I just buy something that will never do what I bought it for?
Old 10-22-2007, 06:27 PM
bisjoe is on a distinguished road
Something is wrong. I have 45 watts (Epilog) and can cut 3/8" wood. With that wide kerf I'd guess you are out of focus.
Old 10-22-2007, 06:37 PM
Exclamation
Now the machine is completely dead. It won't turn on at all. Fans don't spin and no power to outlets for fan and pump. The fuse is OK.
I think today is the day I'm going to start smoking again.
FALSE ALARM! I feel like quite a fool. The software froze up and I couldn't stop the machine so I hit the red emergency button. I forgot to release it (by turning it) after the machine stopped. LOL! Came pretty close to writing a pretty nasty email there for a minute although I wouldn't count that completely out just yet.
Old 10-22-2007, 06:51 PM
Does the kerf suggest I'm too far or too close to the wood?
Old 10-22-2007, 07:25 PM
More likely too close. What you need to do is find out what the focal length of your mirror is, and measure the distance. Whatever tool they provided for adjusting the focus may be out of kilter.
Old 10-22-2007, 07:53 PM
There's no info about focal length and no tool to adjust focus.
I lowered the table and the kerf got smaller but even at 100 percent it still won't go through the 1/32" plywood.
Old 10-22-2007, 10:34 PM
lamicron is on a distinguished road
what speed are you using?
With 40 W I suppose you have to cut it at 4-6 mm/sec, if you are too fast you will only draw lines.
Old 10-23-2007, 06:00 PM
The problem was my mirror alignment. There are two mirrors on a bracket right after the tube and before the X and Y that were about an 1/8" higher than the the tube and other mirrors. I lowered the bracket and then aligned all the mirrors again but this time I got them all dead center and I have a lot more power now.
It still depends a lot on the plywood though. One kind of 1/8" plywood cuts great while another can't even get half way through. I guess it's the layers and the glue. But it will cut the 1/32" very nicely at a good speed now and that's the main reason I bought it.
One other problem I had was cutting arcs and circles. It was making a mess out of them until this morning when I got the idea to tighten one of the belts. Now it cuts perfect circles. Now if I could just figure out the features of this damn Chinese software.
Old 10-23-2007, 06:22 PM
SkipW is on a distinguished road
How did you make out with the .dxf files being too small when imported into NewlyDraw? Did you get that figured out?
Old 10-24-2007, 07:02 PM
I haven't figured it out and I've tried just about everything. Tried importing them to corel12 and then exporting them out again as a new dxf. Sometimes that works but other times NewlyDraw Sends the machine gibberish to cut.
Because of this horrible software (NewlyDraw) my imports can only be dfx's and I've tried every type that corel12 will export to but NewlyDraw sends crap to the machine even though the drawings look perfect on the screen.
And I'm not sending it complicated drawings either. The drawings are very simply sometimes and 3 lines and a curve, but still they cut wrong.
I don't get it and would pay just about anything right now for another software to run this machine, but I don't believe there is another so right now I'm screwed.
  #11   Ban this user!
Old 10-24-2007, 10:23 PM
Have you tried deleting all the NewlyDraw files and reinstalling the software? Like Lamicron has told me about LaserCut, the fifth install is usually the best. When mine acts up, reinstalling it usually corrects the problem.
Good luck to you.
Skip
oz/in to lb/ft to watts 307startup Linear and Rotary Motion 11 10-01-2007 07:14 PM
RFQ: pieces of 0.5" baltic birch plywood in LA gmed Employment Opportunity 2 09-03-2007 05:27 PM
Converting oz/in to Watts mikie Servo Motors and Drives 8 10-06-2005 01:04 AM
Water Pressure to Cut 1/8" plywood? J Solinger CNC Plasma and Waterjet Machines 0 06-05-2005 09:54 PM
Amps, Volts, Watts, explained ynneb DIY-CNC Router Table Machines 2 04-28-2004 07:11 PM
