Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-01-2007, 04:47 PM
Jim Dornon is on a distinguished road
Exclamation Rabbit Laser not working
Hello everyone. Found the forum. Great site. I recently purchased a Rabbit HX6090SC. got it home worked great. The second time I used it the power supply blew. Fan inside was un pluged and over heated. Received a new power supply but not the same. Same wattage but for one of their other machines. They said it would work. Have it installed the way they want it but the laser fires just won't leave the tube ! The laser seems to arc at the metal ring whrer you make the connection for the ground on the laser tube. Any Ideas ? Any one ever hear of this ? I replaced the laser tube with a spare I bought, same thing. Any help would really be great. Thanks, Jim
Old 10-03-2007, 12:59 AM
ArturoV is on a distinguished road
Wish I could help. Maybe next week once mine goes down. These machines have to be tested before they leave the port!
Old 10-04-2007, 12:54 AM
Laser123 is on a distinguished road
Help please.
My new CO2 laser machine has a a working area of 1000mm X 600mm. The software came with the machine is the DSP5.0. The machine only gives about 50% working area around the center of the machine table.
Here is what I want to cut:
[IMG]E:\WorkingTable.JPG[/IMG]
Then I got this message:
[IMG]E:\Exceeds working table.JPG[/IMG]
Here is the machine setting at the default setup of the software:
[IMG]E:\Laser_Machine-Option_Worktable.JPG[/IMG]
Thanks.
I guess I have problem to attach pic here.
ID:	44768   Click image for larger version
Name:	Exceeds working table.JPG‎
ID:	44769   Click image for larger version
Old 10-04-2007, 08:37 AM
lamicron is on a distinguished road
In the software screen Go to file/options/worktable there you can set the size of your table. After that go to printing icon in the software screen and download the config. import the PLT or AI file and download it to the machine.
Use corel 11 to draw export as .PLT . Import to the machine software
Here in the forum to download pictures: go advanced
Old 10-06-2007, 12:53 AM
[QUOTE=Laser123;350253]Help please.
Thanks.
I guess I got the attachments here now.
ID:	44775   Click image for larger version
ID:	44776   Click image for larger version
Old 10-06-2007, 03:34 AM
lazerawy is on a distinguished road
[QUOTE=Laser123;350970]
Originally Posted by Laser123 View Post
Help please.
Thanks.
Please follow these steps:
1- delete all the letters in you drawing except one, ( for example the inner circle of th O letter.
2- click on the 10th button from the left in the button bar, ( zoom to the object).
3-if you cannot see the shape that you left in step 1 filling all the screen that means there are more line outside the working area, check you design.
I hope that helps
Old 10-07-2007, 09:36 AM
When you receive your machine did it come with the size of the table or it was 900 x600 the input? If so, Did you download the config in the laser output? Because you can have that config in your PC as you say onlu have about 50% of centered working area... please check it
Old 10-07-2007, 09:44 AM
Jim Dornon, That arc coming out from the tube, check if the welding has picks , if it is not plain, that can make thi current to jump like that.
Other thing is that the tube could have broken the internal conections for the catode and anode.. BE CAREFULL WITH THAT WIRES 20.000 volts there!!!
Old 10-07-2007, 10:02 AM
Laser
Welding pics. Do you mean were I soldered the connection to the laser tube ? Jim
Rabbit Laser HX6090SC
Old 10-07-2007, 10:30 AM
yes in the anode and catode wires, the weld should be clean , no high points (picks) wire left as a needle, the arc jumps from there
  #11   Ban this user!
Old 10-07-2007, 09:33 PM
ViperTX is on a distinguished road
So, where the Rabbit Lazer Guy.....he always was running around he saying how he could help...Quality Number One....etc. and his little partner aka nemesis....
  #12   Ban this user!
Old 10-12-2007, 02:59 PM
CATastrophe is on a distinguished road
hello guys as a distributing of laser machines in israel i will be happy to give u solution
did u download the new machine cfg file?
downloading the cfg file with correct setting should solve the problem.
CAT
Rabbit hx720 kk_krissy Printing, Scanners, Vinyl cutting and Plotters 12 12-25-2011 02:39 PM
I met Frank with Rabbit Laser pedroman Laser Engraving & Cutting Machines 3 03-19-2009 06:19 AM
Thanks Frank / Rabbit Laser and Dean @ the-lasersedge.com pedroman Laser Engraving & Cutting Machines 17 10-26-2007 04:32 PM
Rabbit laser:need help pbucha Laser Engraving & Cutting Machines 10 09-14-2007 04:32 PM
Rabbit HX5070S vs.IE500 Laser engraver gprocket Laser Engraving & Cutting Machines 2 06-24-2006 07:33 AM
