Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-29-2007, 08:56 PM
abdmalki is on a distinguished road
Corian Laser Cutting
I am planing to build a DIY CNC laser cutting machine to cut a 7mm corian using a 120W CO2 chinese laser tube.
Any body try this before? and for laser experts is this possible?
Thanks,
Abdullah
Old 10-06-2007, 04:09 AM
lazerawy is on a distinguished road
S A Abdullah,
yes you can cut 7mm corian using 120 or even less
Good Luck
Old 03-22-2008, 12:27 AM
FMA1 is on a distinguished road
Originally Posted by lazerawy View Post
S A Abdullah,
Good Luck
Lazerawy,
I am looking at getting a 120w-150w Laser from China. I have been told that at this power they are less stable. Is this your experience? Do you have any advice on getting a Chinese Laser with 80w power or greater?
Warren
Old 03-24-2008, 10:23 AM
buddhafragt is on a distinguished road
yes, that is right!
All chinese lasers over 100W are not stable in output power. We have here a 80W laser and sometimes the power fluctuating some times. Dont buy a laser over 100W!
best regards
Michael
Old 03-29-2008, 12:29 PM
swarfmacdaddy is on a distinguished road
What are you cutting out? What edge cut quality do you need?
Old 04-22-2008, 03:08 AM
Talking
If your cutting any thin sections clean through, the Corian can warp.
I make harmonicas from Corian and some colors are unusable.
I know that sounds weird but darker colors get allot hotter than light colors.
I cut it at 4 inches per min using a 2hp Hitachi router, 2 flute endmill.
I am also using an Exair cold air gun. It helps allot but some colors still warp.
I tried running some through a planer ( scary) and it warped the h@ll out of it.
Beautiful finish though.
Old 05-06-2008, 07:30 AM
mahertolba is on a distinguished road
hello
I am planing to build a DIY CNC laser cutting machine to cut a 20mm wood
what type of laser tube ?
what laser power in watts?
price in us $?
thanks,
maher
Laser cutting CNCadmin Carken Products (Deskam, DeskCNC etc) 2 10-30-2008 09:38 PM
which laser for wood cutting colormecnc Laser Engraving & Cutting Machines 4 09-14-2007 02:05 PM
Looking for someone to do some laser cutting replicapro Laser Engraving & Cutting Machines 1 01-22-2007 03:34 AM
Laser cutting RFQ ??? rsecret Employment Opportunity 2 06-05-2006 08:52 AM
Laser cutting Klox Laser Engraving & Cutting Machines 29 03-14-2006 08:16 PM
