| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Thanks Frank / Rabbit Laser and Dean @ the-lasersedge.com Everyone here has heard my story about the laser I purchased via Frank in Texas from Rabbit Laser in China. The only real downside outside of the software was that my spare tube that I ordered came in busted (poor orientation in the box) so I have had no spare. Well Frank came through along with a new company Dean at www.the-lasersedge.com who is reselling the Rabbit line here in the states. They had ordered several systems and had a replacement tube shipped with them into the US for me. The tube was REALLY well wrapped, shipped standard FedEx Ground and arrived in one solid piece! THANK YOU THANK YOU THANK YOU!!! This really goes far proving that Frank, Dean and Rabbit are serious about taking care of the US customer base. I can't tell you how pleased I am with how it worked out. Frank if I can help you in any way please let me know. My nickel recommendation for what it's worth but I'm HAPPY! Pete aka Pedroman
__________________ Chinese Rabbit Laser HX6090 (60 watt) Happy with it! FANUC CNC (ROBODRILL / TAPE DRILL MATE) 0MC control |
Pete, I wish I was in your shoes. I have had some problems with my machine since the start and I am wondering if you ever had problems with your motherboard? Can you tell me a little more on your machine? I still cant get it to work properly. I have problems with the location of were the laser begins. It doesnt want to start were I have it in the drawing. Can you help me? |
| Arturo, what machine do you have? Try to reset the software,sometimes it does'nt get all the files.. if you want I have other software,you can give a try.. |
| Well got it going! Works great. Is there any way I can send grayscales images to the lasercut software? It only recognizes 2 bit images( black/white)? thanks, |
| Try to export it, not save (from corel) in .AI and after import it to lasercut . Also can do it to PLT. Of course you need AI installed in your PC. Luis |
I only export from Corel (laser doesnt work from corel) to lasercut 5.0 but still get only 2-bit bitmap error. I guess It cant read grayscales? Any other alternatives to get grayscale images engrave? |
| I have this instructions, from a manual, hope you can use it, Steps in CorelDraw(12 & 13): ->import the image -> select the image - -> select Bitmaps Menu - -> select Mode - -> select Black& white 1-Bit ->select conversion method [stucki] and vary the intensity Steps in Photoshop: ->open the image -> select image Menu - -> select Mode - -> select Grayscale -> select image Menu - -> select Mode - ->select Bitmap ->select method [Diffusion Dither] and output 300 pixels/inch |
| I have been able to make decent black and white images(2-bit). But I would like to do grayscale images(8-bit) with more detail and better quality. Is it possible with the kind of Software I am using( lasercut 5.0) ? I get an error when I try to engrave a grayscale image(8-bit). Thanks, |
#10
All laser engravers are two bit, ie. bitmap devices similar to a fax when it comes to outputting non-vector images. The laser can be on or off at a specific power level. I think that the power level is varied by varying the pulse frequency too. so, we rely on software to convert multi-bit images to and convert them to 2 bit images. Some more expensive lasers have the ability to convert in the driver. Rabbit lasers (I have the 6090SE) requires the user to convert the image in a software program like Photoshop or Photograv or other image editing program. Typically, the image is converted to a half-tone made up of black dots of varying sizes and spaces to estimate the "grey scales" of the original image. This enables the laser to burn the image into the substrate. The problem I had at the beginning is that I used a speed that was too great. The result was that the laser didn't have enough power, or didn't linger in one spot long enough to create the dark shadow areas of the image. The result being that the highlights and the mid tones of the images werefine but the areas that were supposed to be dark were mid tones or appeared solarized (reversed from their original tone). The solution is to adjust the speed and the power down until you get the shadow areas to read correctly. I found this by trial and error, it's not mentioned in any literature. First, create a sample of grey shades from 5% to 95% and process it in your software and convert it to a 2 bit image. Then try varying power/speed combinations for each material used to get results that reproduce the sample as accurately as is practicable. You'll learn a lot from this exercise. I know I did and, I quickly found that the max speed quoted for the 6090SE is severely limited by the laser power. This phenomenon I found is not always linear. In other words, the 5% to 80% shades are accurate but the 90% is not reproduced. Experiment, experiment, experiment, that's all I can suggest and , record your results for future reference. |
#11
| Rabbit Laser
That's what I figured. Try and error. Sometimes the only way to learn. Ive done a couple of test now and I still cant figure out what the "scan gap" and "expand scale" boxes do? It would of been nice if somewhere in their stupid manual it explained the differences. Anyways, Thanks for your advice! |
#12
| Scan Gap I think the scan gap is the distance between passes, or resolution. The higher the number, the greater distance between passes of the beam. It should probably be named "span gap". Hope that made sense. SW |
| Rabbit hx720 | kk_krissy | Printing, Scanners, Vinyl cutting and Plotters | 12 | 12-25-2011 02:39 PM |
| Rabbit hxlaser.com Anyone bought from this company?? | Gene-Yo | Laser Engraving & Cutting Machines | 18 | 02-01-2011 09:57 PM |
| I met Frank with Rabbit Laser | pedroman | Laser Engraving & Cutting Machines | 3 | 03-19-2009 06:19 AM |
| Rabbit laser:need help | pbucha | Laser Engraving & Cutting Machines | 10 | 09-14-2007 04:32 PM |
| Rabbit HX5070S vs.IE500 Laser engraver | gprocket | Laser Engraving & Cutting Machines | 2 | 06-24-2006 07:33 AM |
