| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hello all. I projecting a laser cnc project and I would like to understand the basics about the subject. Most of this forum is about about ready to use laser cutter/engraver. First thing I need to get is what wattage should I use. My general idea is that I can use a laser to do cutting of some materials, but I dont know how many watts do I need to cut what type of material. Can I use a 100Watt CO2 sealed tube laser at 30Watts to engrave? The engraving process must take in consideration what type of material I want to engrave? What would be a bad engrave job a hole burned in the piece? Are there solid state lasers 25-50Watts range that could be used to cut or engrave? My intended projects involve cutting wood veneer maybe up to 3mm in thickness. Can I use the same laser to cut and to engrave? The project in my mind looks like a couple of servos, gecko powered to move an XY table, maybe 1m x 1.5m, with a laser tube on the side of the table and mirrors to direct the beam to the work piece. This makes me wonder about what software should I take in consideration. Mach3 will aid me in that? What does that mean, does it mean that I will have to make my own Gcode I wish to cut/engrave? Would I need more software for photo engraving? Many of the ready to use laser cutter/engraver in the market (chinesse and others) use some sort of controller MPC03 for example. What does it mean? Is it a PCI card of sort? What kind of software does it uses? Should I buy something other than gecko´s to drive my servos, some other type of controller more suited for laser applications? Feel free to answer what ever part of this post you want, I apritiate any input. Thank you. Konstantin. |
For 3mm wood 100W CO2 should be enough. Shure you can. Sorry, not understood... Yes, you can (see above). Actually, there is almost no difference between marking (engraving) and cutting. You use low power - burn some material - and get marks, or use high power - burn more material - and cut thru.
There is no straight answer, it all depends on what hardware/software you will use. Generally, it depends on how well (accurate, fast) you can control your laser power/frequency, and how it is implemented in a software. Motion system is almost absolutely independend from what laser hardware you will use. |
| Konstantin I recomend you, easier to buy a chinnesse cheap machine , and make all changes you want, you 'll get it in less time, less money.125x90 machine with 80 w laser will cost you about $4000 Fob china, and you get laser for 1000 hours. Luis |
| Why buy a Laser cutter when you can modify a laser engraver. | spacifique1 | Laser Engraving & Cutting Machines | 7 | 08-13-2007 03:39 PM |
| 2000 W Laser machine | Cafrebus | Laser Engraving & Cutting Machines | 2 | 06-27-2007 02:03 AM |
| building laser machine | woodfish510 | Laser Engraving & Cutting Machines | 3 | 04-11-2007 08:34 PM |
| laser cutting basics | BeeleJuice | Laser Engraving & Cutting Machines | 3 | 01-29-2007 07:44 AM |
