Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
  #37   Ban this user!
Old 04-13-2009, 12:31 PM
zax15uk is on a distinguished road
Originally Posted by Big View Post
If this laser came with a Controller software "plugin" for Corel like many other lasers,then the Chinese manufacturer would see a big increase in their profits. How hard can that be?
If the resellers pushed for this change then these little machines would be flying out the door.
Most of the Chinese systems do come with a Corel driver, some brands only have it on the mid to high end and others have it across the board.
The cheaper engraving systems usually come with dedicated software.
Zax.
  #38   Ban this user!
Old 04-16-2009, 05:53 PM
Magritte is on a distinguished road
Originally Posted by valbyrne View Post
Hey guys, I just bought a HX 3040 that works with newlydraw but when I try to press many of the buttom inside the engrave browser, including start engrave it shows me an link error:2 message.
Do anyone knows why??
I have the same machine and had the same problem when I was trying to run the engraver through a usb to parallel cable. When I connected it using the serial cable provided it worked fine.
So i guess it means your pc is not communicating with the machine. Have you tried a different parallel cable? Or a different machine?
  #39   Ban this user!
Old 04-16-2009, 05:58 PM
Originally Posted by zoranp08 View Post
I have a Shenhui Laser DC-G350B. The software that came with it is Newly Seal 11 and it does not have vector cut. Does anyone know if I purchase NewlyDraw if the machine will vector cut.
At the moment I can engrave and can only cut square or circule.
Thanks alot.
NewlyDraw with my rabbit 3040 can 'scan' (which is like a printer) and can cut vector lines too using 'cut'. Though I would far from recommend buying NewlyDraw its still pretty painful to use.
  #40   Ban this user!
Old 04-16-2009, 06:24 PM
When I import files from autocad in to newly draw does anyone know if i can change intervidual lines on the autocad work so I can e.g cut some and scan others.
What i am trying to do at the moment it make things out of cardboard. So would like some lines to be engraved (so i can bend them along the engraved line) and then cut round the outside of card board net. To do this at the moment I make two files in autocad and import them seperately and hope I get them in the right place. Does anyone have a better method or can give me some pointers on how use the layers in newly draw?
  #41   Ban this user!
Old 04-17-2009, 09:46 AM
Magritte, it depends on how the artwork is created but yes it is possible to select some elements to be raster (scan) and others for vector (cut).
When you import the file, everything is grouped. Click on 'split' and it will ungroup all the elements so you can select them individually.
You can also use the layers in Newlydraw to make everything align correctly, this is useful if you want to use different laser power or speed for different elements of the design. If not, when you send the file to the laser it moves the origin and the elements don't align.
Zax.
  #42   Ban this user!
Old 04-17-2009, 10:49 AM
thanks zax15uk thats a great help.
  #43   Ban this user!
Old 06-09-2009, 01:51 PM
arachid78 is on a distinguished road
question about laser newlyseal
Hello, I bought a laser cutter engraver on ebay. I receievd a cd with software and usb key, I installled the software and it's newlyseal 11. I tried it but i can find how make acrylic shape with laser cutter.
I don't know if newlysoft and newlydraw is the same software (on the cd I received it show newlysoft and newlydram but when installe i have only newlyseal. I find newlydraw on web and download it but teh softwaer is in chiness and indicate i don't have usb key to open it. any body can help me?
can i control this machine with other software? can I by newlydraw?
i bought dc-k40iii
  #44   Ban this user!
Old 06-09-2009, 02:36 PM
Newlyseal is designed for making rubber stamps and does not have all the features of Newlydraw. It may be capable of some basic cutting but you really need to obtain Newlydraw.
I believe the dongle "key" is different so you probably need to arrange an exchange with the vendor.
Zax.
  #45   Ban this user!
Old 06-09-2009, 08:14 PM
Hello, where I can get newlydraw? the vendor don't answer me. I don't find newlydraw vendor.
  #46   Ban this user!
Old 06-10-2009, 07:36 AM
Newlydraw is produced by 0123, the same company as Newlyseal but the problem is each dongle and version is specific to the driver card.
http://translate.google.com/translat...w.0123.com.cn/
I suggest contacting the manufacturer of your unit, which I believe might be Qingdao Digital?
http://qdmagnetic.en.china.cn/
If you don't have any success there are 2 options. Purchase a new driver card and software from another vendor (Rabbit, WK or Artsign for example) or convert to a generic driver board and use Mach3 or something similar to drive it (would be my choice).
Zax.
  #47   Ban this user!
Old 06-11-2009, 04:54 AM
Frans_K is on a distinguished road
I'm looking for a new driver board and software for my HX40A laser.
Is it possible to engrave and cut with mach3? of is there better software for engraving?
I've found these boards: http://www.routoutcnc.com/lpkits.html they seem like a good deal.
With kind regards
Frans Kampkes // The Netherlands
  #48   Ban this user!
Old 06-11-2009, 06:28 AM
Hi, seller says my laser is not compatible with newlydraw just newlyseal and 0123.com.cn sasy it's compatible. can you comfrim my machine is compatible before i bought newlydraw?
Questions on building small (18" x 24" x 3") machine bikedude880 DIY-CNC Router Table Machines 4 07-31-2006 09:04 PM
