| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
#13
| Hi Niklas, There are two cases: 1- If the shapes on the sheet are just a repeats then just do that steps with the first shape then repeat it. 2-If the shapes on the sheet are not the same, then you should to apply that steps to every shape on the sheet or in some cases you can combine all the shapes then let the rectangle to intersect with them but don't forget to open the shapes. Also take care with the shapes that has many shapes inside (Ex. letter B [it has two inner curves inside the outer curve]). |
#14
| Hi Niklas, Here is another method for complicated shapes. -Select the knife tool (use it to open any curve). -Disable auto close-on cut (knife tool options on tool bar). -Cut a point on each curve including the internal curves to open every curve. -Get the half cut(gap) area using a rectangle(the previous steps that I post). Osama |
#15
| Hey guys, why not just change the outline (that you would be using to cut the figure out) to a dashed line, with long dashes. In autocad you can change line types very easily, plus you can either make up your own custom lines, or just pick a dashed line type and change the line type scale. Changing the line type scale changes the length of the dashes and the spaces in the lines. To do this is likely about 20 seconds worth of work. Why bother trying to cut the line up with rectangles and so on, that is way too much time consumed for a simple process. I am not too familiar with Corel yet, but I would imagine that you might be able to change the outline to a dashed line of some type. I also like the idea of only cutting about 95% of the way through, except that this method could leave you with a lot of clean up to be done all the way around the edge. The other draw back to this is that you need a special power setting for every single type of material and thickness you come across, whereas the dashed line could get you through several types or thicknesses of material with one or two general settings. Pete |
#16
| We need to cut the shape totally but we need to get some half cut area to keep that shape within its material like the wooden or acrylic kits, so The main problem in dashed line that there will be gaps in your shape, without cutting or half cutting those gaps the shape will not come out from the material. Osama |
#17
| Hi Osama , there is another way to hold your cut pieces in place, cut it as a mirror (inverted , for the back side) some materials cut better this way and leave better shape, after you cut, put some contact vinyl adhesive over the plate and then you have the front of your product clean. Be sure to use a not aggressive glued tape or vinyl, you can use that blue one used to protect the acrilyc plates from scratches, it holds not to tigth and is easy to peel off Luis |
#18
Good idea [If accepted by Niklas ], We are using some kind of masking tape(used with vinyl as backup to remove and past) to do it . |
#19
| Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
| Corel Draw and Mach3 | Rodm1954 | Machines running Mach Software | 11 | 12-09-2007 12:24 AM |
| Corel Draw 9 Question & Help | W4MWK | General CAM Discussion | 3 | 02-14-2007 09:38 AM |
| Anyone exporting from Corel Draw 10? | ShayArnett | SheetCam | 12 | 05-27-2006 02:52 PM |
| Where to get Corel Draw? | WarrenW | General CAM Discussion | 7 | 12-29-2005 03:07 AM |
| Corel Draw question | ljoe1969 | General CAM Discussion | 8 | 07-22-2004 06:22 AM |
