08-01-2007, 03:45 AM
 | Fractal Pyramid | | Join Date: Feb 2005 Location: Egypt
Originally Posted by Carl26 Hello, I am new here. I'm not sure if this is the right place to ask for help, but here goes. Please bear with me while I try to explain my problem. I am trying to cut out a company logo that I found online. The logo was originally a .eps (encapsulated post script) file.
I open that file up in CorelDrawX3, save it as a .dxf, then open it up in AutoCAD for editing. In AutoCAD, the drawing is there, but all of the lines are splines. I then save and open it up in AP100 (Amada's laser software for generating NC code). It takes longer than usual to open the file in AP100.
Then once I make the NC code and send it to the laser, it will cut, but the feed-rate is very slow and it creates a lot of small ridges on the edge of the cut instead of a smooth edge.
I'm not sure if I should be doing something else with the file before or after I save it as a .dxf. Soemthing tells me that the problem is the spline. It should be lines or polylines. Has anyone else had a similar problem? Any suggestions? Thank You,
Carl |
Hi Carl,
What are the files type can be opened or imported to AP100 software, also if you can attach your original eps file and exported dxf and final nc code, I can do some trials to help. |
