Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-08-2007, 03:10 PM
goddessofchaos is on a distinguished road
Question re computer for Laser software
I have ordered the 3040 laser and now will have to make things ready for when it arrives. Since I am a Mac person I will need a windows computer and have a source for reconditioned machines but have some questions about what to look for. I was told a pentium processor - any special pentium? How about Athlon? The cost is about $100 less and athlon speed is listed at 200 MH (does that sound right?) It will be fully dedicated to the laser so I don't need internet connection (I don't think). How big would HD need to be to store the laser program and I assume I will want to store some of my graphics designs as well to have them easily available.
You folks have been so helpful - not sure what I would have done without these forums to get info! Thanks all!
Jacqui, Goddess of Chaos, GSOLFOT
Old 06-11-2007, 12:00 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
Smile
Hi jaquie,
This is what the forum is for. I too would be stumped if it wasn't for all the generous people out there willing to give their precious time.
The laser itself will work from an old 386 computer but you will need a fairly fast one if you are going to do design work as well as running the machine so I suggest get the fastest one you can afford. Anything over 2 GHz (gigahertz) would be satisfactory. Athlon, Celeron, Pentium etc will all run the same software and the only difference is stuff like larger on board cache memory or maths floating point co-processor on the chip which shouldn't be needed unless you are running very graphics intensive stuff like 3D games or 3D drawing programs. The chips are so cheap now that you should just get the fastest one you can afford.
Check out www.Dell.com as they have some very cheap NEW computers and you can mix and match what you want in them and also get a good warranty period and also the latest fast computer (I don't think you need the duo core or 64 bit chips though. Just a single core 32 bit chip will do). Sometimes they have a special on computers and a basic one starts at $459 with monitor.
If you already have a monitor, don't buy one. Same as a keyboard, mouse, system box, power supply or any peripherals you may already have but as you said you are a Mac person so you or your friends probably won't have these laying around. Over the past 4 years my friends have been looking out for computers for me as they know I use them fairly often in my hobby so now I have about 7 of them and LOTS of peripherals and can mix and match some parts and build some workable machines out of them.
Get the largest hard disk you can afford as it will be where you store everything that you will be doing. Your files will build up as you go and if you are sentimental about old stuff then you won't delete many, if any, files as you gain more experience. I wouldn't get anything under 120 Gig. ($109.00 AUD) Also partition the drive into 2 different partitions and save all your work on the second one because if anything happens to the C: partition then all your files will be ok on the D: partition if you have to reformat the drive through a corruption like a virus etc. I know this from experience. Also a backup program is essential if you don't want to lose any data. Ask at your local computer store for which one is good and easy to use as there are many out there and some even free. You can even play music on the computer while you work if you haven't a radio close by.
Also try to find a card reader to put in it as heaps of people use these things now and they are extremely good for transferring files from one place to another. In the winter months I design work inside the house where it is warmer and transfer my files to the machine in the shed this way using the flash drive. I have 1 Gig for $32 AUD (cheap) 1 Meg files take about 2 secs to download. I used to use a CDRom drive but found it way too slow compared to Flash drives.
All I can think of for now but keep the questions coming as it just doesn't help you.....it helps everyone out there interested in starting up (and we all had to start somewhere).
Now. Have you got a wiring schematic in ENGLISH for my Chinese laser power supply ???
warm regards
Rich.
I am not completely useless.......I can always serve as a BAD example.
TurboCAD/CAM - Is it the software or my computer? Clockwork TurboCAD/CAM 4 06-10-2007 08:24 AM
Question about the computer used for a CNC router marksnwv Computers and Networking 14 11-14-2006 09:54 PM
computer question for new cnc router woodworker2 Commercial CNC Wood Routers 5 05-12-2006 11:11 PM
Help with picking proper software for computer landart Mach Software (ArtSoft software) 1 03-29-2004 02:18 AM
Computer and software selection question Darren_T DIY-CNC Router Table Machines 10 02-24-2004 11:32 AM
