| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I just hooked up my laser and in the test mode, I get a visible ray inside the tube but it does appear to have a hot spot near the output end and it looks like a short. I can't tell for sure and without enough experince I am hoping someone here has an opinion. Definately no output as a peice of paper is quite safe at the output end. Sorry for the poor quality http://www.youtube.com/watch?v=lQmJfVPpRDE Opinions? Thanks Mike Purcell
__________________ www.classicplayfields.com |
| Well, the tube appears OK now, or at least I think it is. The PCI driver card MPC03 is/was acting up. After a dozen reinstalls all of a sudden the I get a much brighter beam inside the tube and can actually cut some 1/8" acrylic at about 7mm a sec at 95% of the 80w available. I thought it would cut faster but maybe something is not adjusted right yet. Mike
| Something is definetly not right. I have a 40 watt tube and I could cut through 1/8" acrylic at 30 ipm at maybe 70 to 80 percent power. I was surprised at how much power those things produce. I very rarely take mine to the full 40 watts. I can only imagine with 80 watts. |
| Hello ! I am using a 100W CO2 laser tube and the fluorescent light (due to nitrogen transitions) is very uniform across the tube even much below the lasing threshold (around 6 mA). No hot spot like with your tube. If you think your tube is producing more lasing power than it should, perhaps there is something wrong with your power supply. If the tube current is to high, your tube will be destroyed within a short while ! |
| I have the laser up and working well. It seems that the PCI card was restricting power somehow. I installed it in a different slot on the computer and everything now appears fine. Thanks Mike
http://www.cnczone.com/forums/showthread.php?t=37833 oops the other guy was you lol sorry
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| bad laser tube | CNCadmin | Laser Engraving & Cutting Machines | 40 | 07-03-2007 10:23 PM |
| Tube through a Plate | CharlesM479 | Solidworks | 6 | 04-14-2007 01:33 AM |
| Sealed tube gas mix... | WilliamD | Laser Engraving & Cutting Machines | 6 | 12-10-2006 10:27 PM |
| Flame Tube | InfamousX241 | Jet Engines and Ram Jets | 2 | 11-05-2006 06:27 AM |
| Tube and profile bending | motordude | Bending, Forging,Extrusion... | 1 | 03-12-2004 10:01 AM |
