| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
here is a web page that may be useful for all the laser enthusiasts out there for proper care and cleaning methods for their laser systems http://www.iiviinfrared.com/ttr_opticsclean.html (formerly Laser Optics) I also read somewhere that if the lens is really dirty but not scratched then you can wet a piece of absorbent paper with isopropyl alcohol or acetone and slowly drag it across the lens/optic without applying pressure to rid it of detritus. Hope it helps you. Richard.
__________________ I am not completely useless.......I can always serve as a BAD example. |
| Ok. But that was not the intention of showing this web site. It has to do with cleaning of the optics which can be related to all the optical components.
| The drag method with lens tissue is much preferred. I would never apply a moistened cottonball to dirty optic. Keep your optical grade acetone sealed as it draws moisture that will leave water spots due to the different evporation rate. Never re-drag an optical surface with a used lens tissue surface, always use a new surface to avoid re-contamination. Cotton balls, even medical grade may have a small % of cotton seed fragments in them, as well as residual cotton seed oil. Optics are important to laser processing. Imagine someone licking your safety glasses and you having to wear them like that.
__________________ Brian www.precolaser.com |
| Yes, I think that I would have preferred the drag method myself as it just sounds less abrasive and only uses surface tension for the mechanical effect. I don't think I would rub anything that is supposed to be a lens surface. I have always used a blower brush on my cameras and they have never been dirty enough to warrant a wash with anything and I have always chosen the expensive Squirrel haired brushes and not the man made fiber ones.
| Engraving Curved Optics | harlequinir | Engraving Machines | 1 | 04-18-2007 08:16 PM |
| Fiber optics!!! | kolokithas | DeskCNC Controller Board | 1 | 12-04-2006 10:11 AM |
| ebay auction -- nice optics | owhite | Laser Engraving & Cutting Machines | 3 | 08-09-2005 02:30 PM |
