Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-13-2007, 09:47 AM
Bread_O is on a distinguished road
Info Required For Acrylic Cutter
Can anyone give me more information on the type of laser I need to cut acrylic sheets about 5mm thick so that I get a clear finish on the cut. Preferably I want to build the table and the laser. Any information will be appreciated.
Old 04-14-2007, 09:09 PM
lcshkevin is on a distinguished road
cut acrylic sheets about 5mm thick , i think you can use 80w laser cutting machine, can you tell me the width and length of your acrylic sheets, then i can suguess you a type of machine in our factory, i you would like.
Old 04-15-2007, 02:14 PM
The average size I would need to cut would be about 500mmX500mm but I was thinking of a table size of 1000mm X 1000mm so I would be able to mutiple pieces at once. Also would I would like to find out if a laser cutter would be able to make small holes as well (approx 1.5mm).I would be cutting 3mm / 4mm and 5mm acrylic.
Old 04-16-2007, 03:03 AM
DC-G1290 laser cutting machine
if cut for that size, i think you can use DC-G1290 size:
Technical Parameters
Laser Power 80W
Supply Voltage 220V
Max width 1250mmx900mm
Engraving/Cutting speed 1000mm/s
Locating Precision <0.01mm
Min shaping character Character:3×3mm Letter::2×2mm
Operating temperature 5°C -26°C
Resolution 0.015mm
Control Configuration DSP
Data transfer Interface USB
System Environment WINDOWS2000/ WINDOWS XP
Cooling Way Water Cooling and Protection System
Graphic file format BMP,GIF,PCX,TGA,PLT,CDR,DXF,AI
Cutting thickness 0 – 20mm
Color Separation Yes
Cuts off the water supply the protection Yes
Slope Engraving Yes,360° slope can be designed easily
Net Weight 200kg
Machine dimension 1700x1200x1150(mm)
hope this information is useful for you, i am the munufacturer of laser machine
Kevin
E-mail: lcshkevin@yahoo.com.cn
Old 04-16-2007, 04:19 AM
price?
Old 04-16-2007, 07:40 PM
laser cutting price
have you received my price?
Kevin
Old 04-16-2007, 09:38 PM
laserengraver is on a distinguished road
laser cutter for acrylic
We also have the laser cutter can do good job for acrylic cutter. If you like, I can send you some vedio on the laser cutting on the acrylic 3mm-8mm.
my yahoo email:
lasermachine2007@yahoo.com
Old 04-16-2007, 09:41 PM
We also have the laser cutter 80w can do good job for acrylic cutting. If you like, I can send you some vedio on the laser cutting on the acrylic 3mm-8mm.
my yahoo email:
Old 04-17-2007, 03:53 AM
ok, please send to me
please show to me
thanks
kevin
Kevin
Old 06-03-2007, 12:45 PM
sabot1911 is on a distinguished road
hi,
i am unable to contact on your mail Mr laserengraver on your following email address "lasermachine2007@yahoo.com"
I am looking for laser cutting machine for acrylic, kindly send me your product specification and price list and let me send demo video for laser cutting process for acrylic.
  #11   Ban this user!
Old 06-03-2007, 06:26 PM
LarryB is on a distinguished road
35 watts will cut that. My Epilog 40watt will cut 1/4" acrylic no problem.
Larry in South Carolina
  #12   Ban this user!
Old 06-03-2007, 08:45 PM
laser cutter for Acyrlic
Dear Sir,
i have write private email to you, hope you have received it , and hope will contact me from my contact as below, and please tell me yur contact email, i will send my parameter to you, and give you a price.
Your faithfully,
Kevin Zhang.
Tel:0086-13563522963 Fax:0086-635-8511101
Skype:lcshkevin MSN: lcshkevin@hotmail.com
E-mail: lcshkevin@yahoo.com.cn Website: www.lcshenhui.com
www.shenhuilaser.en.alibaba.com
Factory Add: Changjiang Road ,Liaocheng Economic Development
District, Shandong Prov. , China .
Kevin
Sanyo Denki info required edmond Stepper Motors and Drives 0 04-07-2007 05:18 AM
info required about fanuc macro programming sinha_nsit Fanuc 11 04-06-2007 09:13 PM
Acrylic blfuller123 DIY-CNC Router Table Machines 3 12-28-2006 08:15 AM
Acrylic Mike7 Vacuum forming, Thermoforming Etc 2 10-30-2006 10:16 AM
