Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-23-2007, 10:53 PM
nicklv is on a distinguished road
how to control laser head movement from PC
I'm a newbie to laser cutting and i'm trying to understand how laser head movement (xy movement) is controlled from the computer. What kind of interface board and software to use.
Appreciate your advise.
- Nick
Old 03-01-2007, 08:10 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Well, it is controlled like a regular cnc machine. Just search on the forum here for Mach3 cnc. It is a cnc control software that reads g-code and send out step and direction commands out the parallel port of a windows XP pc. Then you need a few drives that take step/dir signals from the Pport and run the motors you want to use, some like this: geckodrive.com. First start with stepper motors this will be cheaper and simple, then latter you can go to servos for more speed if you need to. To generate the g-code for the sofware you will need CAM software. To make you drawing you need CAD. So once you have the machine step up it takes a few minutes or less for simple parts to be made. Just do a lot a lot of reading here on the forum and you will be a wiz.
Dennis
Old 03-01-2007, 08:40 PM
vladdy's Avatar
vladdy is on a distinguished road
One of the simpler laser 'adaptations' that I've seen is simply to align the laser [laying down] along the X axis, a 90 degree mirror that's on the Y axis, and another on the Z axis carriage...
pretty simple, especially for a lower power 'hobby' laser for paper [gaskets, etc.] or easily cut things like plastic or balsa wood...
don't forget the safety shades...
enjoy...
No Movement wishmasterg Mach Mill 3 02-14-2007 06:39 PM
Laser head pricing? Zumba CNC Plasma and Waterjet Machines 5 10-06-2006 08:57 PM
Axis Movement UKRobotics General Metal Working Machines 2 12-17-2004 01:33 PM
4th axis movement (and a few other gen ?s) corpse General Metal Working Machines 2 08-04-2004 06:13 PM
Gantry movement ynneb DIY-CNC Router Table Machines 11 02-15-2004 02:04 AM
