Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-23-2007, 05:09 PM
max_imum2000 is on a distinguished road
what is laser beam combiner ?
hello
i need someone to explain the function of these optics used in co2 lasers.
ZnSe beam combiner vs GaAs beam combiner
focasing lens vs beam double focasing lens
does these comes as standard sizes and or i should calculate something ?
thanks a lot
Old 02-24-2007, 06:48 AM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
ZnSe and GaAs are just the types of material that the lenses are made of.
ZnSe is Zinc Selenide and is harder than the GaAs Gallium Arsenide crystals which last a bit longer when in rugged environments and more frequent cleaning is needed.
The beam combiner lens is held at a 45 degree angle directly in front of the laser beam and you have a red laser beam shining onto the 45 deg face of the lens that combines the two beams together. The Co2 wavelength is invisible to the naked eye but the red laser is visible making the setup process for the job much easier because after the bending of both the lasers through all the mirrors and onto the job surface you can see where the red laser is situated and where the CO2 laser will start cutting.
The focusing lens does just that, it focuses the beam into a smaller dot onto the job which increases the beam intensity many fold allowing it to cut with a smaller kerf (cut width) and through thicker material.
The beam expander widens the laser beam, say from 5-7mm to 10-15mm before it is passed through a galvanometer head or focusing lens which has the effect of making the point contact of the beam very small in the neighborhood of only a few thousands of an inch (but less cut depth because of the beam angle) which also increases the power density of the beam at the point making fine engraving possible on metals etc whereas the normal beam would not have enough power at its normal width and would also be too wide for practical engraving use.
The following URL has some very good explanations for you in this subject. Just click on the links and brows to your hearts content.
http://www.sintecoptronics.com/
Hope all this is understandable for you and it helps somewhat.
The Neuron.
I am not completely useless.......I can always serve as a BAD example.
Old 02-24-2007, 11:31 AM
great post
thanks a lot for your time
one last thing
is differnet laser power has differenct focal lens
i mean do i calculate it ?
also what is double focasing lens ?
thanks again
Beam Expander CNCadmin Laser Engraving & Cutting Machines 9 07-12-2007 01:35 PM
Laminated Beam lgroulx200 DIY-CNC Router Table Machines 0 10-23-2006 09:43 PM
Laser beam delivery smartcut Laser Engraving & Cutting Machines 3 10-17-2006 07:55 AM
Looking for Beam Couplings Robyn Mechanical Calculations/Engineering Design 2 03-24-2006 06:40 AM
Short beam/Long beam? - Basic design Pat2000 Mechanical Calculations/Engineering Design 5 11-09-2005 10:49 PM
