Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-25-2012, 08:25 PM
Xanadu is on a distinguished road
Synrad CNC setup
Hi guys, newbie to lasers here and a I have a couple of questions I'd like to run past you.
I have a Synrad G48 that is on a CNC gantry setup to cut fabric. I have all of the components in a disassembled state (laser head, UC-1000 controller, SPL250 power supply, Arrick MD-2 CNC controller, water pump and a suction pump.
I bypassed the safety switch, manually opened the beam shield and powered the unit up in manual mode - zap! It scorched the block I put in place to safely deal with the beam. So it looks like I have a working system, most excellent.
Question 1 - No computer came with the setup, what software will drive the Arrick MD-2 controller? What OS will I need to put on the PC? I know there can be issues with parallel ports, what should I look for?
Question 2 - The laser head is clearly marked 30W but the manuals online for the Synrad G48-1 series specify that it is a 10W unit...?
That is it for now, I have a lot of work ahead of me to get this back into fully functioning condition.
Thanks for any advice!
-X
Problem- SYNRAD FLYER Quesha1 Engraving Machines 11 09-23-2011 04:51 PM
Please HELP! Synrad control zoltan Laser Engraving & Cutting Machines 21 07-06-2011 02:22 PM
Synrad 48-2 cinematic2 Laser Engraving & Cutting Machines 3 06-10-2011 02:09 PM
Synrad Vs GSI MisterP Laser Engraving & Cutting Machines 1 04-28-2009 12:31 PM
New Machine Build- Synrad vs chinese fogassa Laser Engraving & Cutting Machines 0 11-25-2008 10:21 PM
