Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-23-2012, 05:05 PM
dominic gailgan is on a distinguished road
laser poor results
Hi I have a k40 type Chinese laser engraver. I have had lots of trouble aligning the beam. But I'm unsure what this machine will do. The tests I've done so far have only given a burnt image but no engraving. Should this machine be able to engrave wood, plastic, ect? If so how do I get it to do so?
Thanks Dom
Old 01-23-2012, 10:09 PM
mondo50m is on a distinguished road
I have the same machine. I have cut acrylic and birch plywood with mine. Unfortunately, my power supply went 'belly up'. One is supposed to be on its way to me. I have engraved on Lexan, Acrylic, plywood, tiles, and granite, with some good results. Get it lined up and you should be fine. Mine focuses at 50.8mm. Yours probably does also.
Milt
Old 01-23-2012, 10:19 PM
Hi sorry for this but what do you mean 50.8mm to focus? So when you say engrave do you mean that it does more than burn? Is mine only burning because it's not focused properly? And how do you focus your machine?
Thanks Dom
Old 01-24-2012, 01:32 PM
Exsecratio is on a distinguished road
Hiya Dom,
Have a read of this for an explanation of depth of field and focal length.
OPLaser support forum • View topic - Understanding Depth Of Field (DOF)
best wishes
Dave
Old 01-24-2012, 02:52 PM
Thank you that answers some of my questions about why I'm only getting a burnt effect no engraving. It's a pity the seller did not give us a descent manual with this machine. Or answered our questions. But what can you expect from a chinese drop shipper selling on ebay. We had our fingers burnt but are just trying to get this laser going. I hope now armed with this focusing information as well as beam setting information we'll get it going.
Thanks Dom
Need Help!- Why I don't get better results?? KSPATZ MadCAM 13 04-09-2011 03:00 AM
BF20 (G0705) Power Draw Bar Build (Poor, poor mans drawbar) zerodegreec Benchtop Machines 6 09-14-2010 03:01 AM
Facemill results turbo2ltr General Metal Working Machines 5 02-09-2010 02:45 PM
PCB MILLING WITH BAD RESULTS cwiliam PCB milling 7 06-15-2009 04:15 PM
Poor results, help please! Swede Hard and High Speed Machining 8 04-03-2004 10:23 PM
