| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi guys, I have absolutely no experience with CNC machines but am on the hunt for the best way to cut small shapes out of marzipan or icing sheets to be used in cake decoration... Any advice would be greatly appreciated.... I'm wondering if the best plan of attack would be to freeze the sheets to make them stiff and then use some type of router type spinning drill bit to cut out the shapes? But I'm hoping someone with more experience might be able to give me some good advice.... Laser, blade, spinning bit etc???? |
Thanks for that info.... Will look into that too.... Home craft sort of budget so less than $1000 hopefully for a suitable method... |
| I would attack it from another direction. Make molds or cutters with a cnc to cut or form the icings. I would hate to be the one cleaning the rails of icing and marzipan at the end of each day and having to re-lube everything. |
| These machine use knives to cut the material. Cricut Cake I'd guess that the blade approach would be best.
I'm beginning to think a blade based system for the larger stuff and then some sort of ink jet printer type device for the smaller more intricate text and design touches... |
| Newbie- I need to buy a small laser cutting machine for pc sheets | memerik | Laser Engraving & Cutting Machines | 4 | 08-04-2011 08:47 PM |
| Need Help!- X3 SET UP SHEETS | CNC_BOB | Mastercam | 2 | 03-16-2010 09:10 PM |
| What CNC machine do I need for Aluminum sheets up to 0.09"?? | jascamera | DIY-CNC Router Table Machines | 1 | 12-24-2009 11:05 PM |
| Build Thread- set up sheets | 1234567 | BobCad-Cam | 4 | 10-27-2009 01:38 PM |
| Newbie- Need CNC machine to cut .01" 302 full hard SS sheets (6" x 20") | Lowe | Want To Buy...Need help! | 0 | 03-23-2009 12:58 PM |
