| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hello, I* am doing laser cutting with multiple coloured designes on a layer. When I cut them, due to the width of the laser, there is a gap between the pieces when assembled. I have looked at other peoples work but this doesn't seem to be the case with them. I line them up exact in the software when they are being cut and have also over sized them to try get rid of the gap, but this is an issue as it can mean that they are accidentally made too big sometimes so then need sanding. I want them to fit tight like a jigsaw would. Also I was wondering if there is any other easily available software for laser cutting as I dont like the one that came with the machine. I have newlydraw. hankyou Amy |
| When trying to do that tight inlay work, the only way to get it "perfect" (that I know of) is to compensate for the kerf. You'll need to figure out your spot size to do this, and some work on the drawings. I usually break my drawing into pieces, and then offset the individual pieces by 1/2 of the kerf (inside piece bigger, outside piece smaller). Depending on thickness and focal length, you can also try cutting the inner piece upside down to compensate for the beams's cone. If you're randomly getting spots tighter than others, it could be machine accuracy, or beam quality... and may, unfortunately, require a little hand finishing. I've never seen laser cut inlay look perfect... |
| I've been using Corel Draw X5 for a while now, and it's pretty good for drawing parts for the laser. Quite powerful, and far simpler than Adobe Illustrator. Copies sell on eBay for around $100. For what you've described, I use the contour function to draw those slightly larger lines. You might also look at InkScape - it's a free vector drawing program. I've used that before as well, but I don't know what formats it will export to... |
| Tags |
| laser, lasercutting |
| Newbie- DXF to GCode software for laser cutting? | scriptster | G-Code Programing | 6 | 02-07-2012 02:54 AM |
| Laser thickness issue | wickedboysap | Laser Engraving & Cutting Machines | 10 | 03-01-2011 02:06 AM |
| Need Help!- Software FOR LASER ENGRAVING AND CUTTING | graficasmedit | Laser Engraving & Cutting Machines | 5 | 08-17-2010 08:27 AM |
| Laser engraving and cutting machine - software help! | hamleet | General CNC (Mill and Lathe) Control Software (NC) | 8 | 08-13-2008 12:39 AM |
| Software for laser cutting | PeterCharles | Laser Engraving & Cutting Machines | 0 | 11-24-2007 07:47 AM |
